Like Tree2Likes
Old 01-22-2013, 06:56 AM   #496
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
Wow, lucky you didn't break the front of the chassis with it tweaked like that.
Nice catch, RCTech comes through again.
Jon Carlson
Team Associated, Reedy
Futaba, OS Engines, O'Donnell Racing Fuel
Jon Carlson is offline   Reply With Quote
Old 01-23-2013, 06:36 PM   #497
mnracer's Avatar
Trader Rating: 25 (100%+)
Originally Posted by zipperfoot View Post
Finished the build,and decided to go 1.3mm, 4 hole pistons with Avid Red Springs all around. All I can say is wow. The truck was planted on a dry, dirt track. I am really impressed with this truck. No weight, shorty pack mounted forward, and it was perfectly balanced. Stock turn buckles and ball cups. Everything worked great, no issues. Went through 3 packs of testing.
What were you running for shock oil front/rear?
Billy D
mnracer is offline   Reply With Quote
Old 01-23-2013, 06:39 PM   #498
mnracer's Avatar
Picking up my kit tomorrow... I don't find too much setup info about this truck. I am familiar with Durango. What drive setup is everybody running? I really like the RM4 in my Dex210... but was considering mm with the truck???? Thoughts....
Billy D
Old 01-23-2013, 06:46 PM   #499
DBL15's Avatar
most are running the same set up in the truck as we are in the buggy mate its a good starting point
C/O Coast2coastrc (www.coast2coastrc.com.au) SMC Lipo
Tekno Rc , Team Tekin , Panther-Rc , De Racing , Upgrade Rc , Team Triton rc , M2C clutches , Nitro X fuels
DBL15 is offline   Reply With Quote
Old 01-24-2013, 06:17 PM   #500
mnracer's Avatar
Any other setup tips? Front caster?
Billy D
Old 01-25-2013, 09:07 PM   #501
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Losi 32.5 front, 30 rear.
zipperfoot is offline   Reply With Quote
Old 01-27-2013, 11:48 AM   #502
Trader Rating: 57 (100%+)
When you loosen the slipper, do you actually hear it slip for ST? I have a DESC210 and I slip about a foot or two and it's easy to hear. I loosen the slipper quite a bit on the DEST210 yesterday and I didn't hear it slip.
Once your diff is set, do you folks ever adjust it? Seems all the adjustment nowadays is to the slipper.
shagino is offline   Reply With Quote
Old 02-01-2013, 08:20 AM   #503
zipperfoot's Avatar
My hearing is not very good, so I never hear any slippers slipping, unless I'm standing right of the car. I tune mine more by the table top method and holding the wheels. I then test it on the track, judging more by traction. I also can also tell by how well it clears jumps. If I have trouble clearing a medium sized double, I tighten up the slipper a bit. If the truck is controllable, and clears jumps like it should, it's good enough for me. Thats why I am a middle of the pack driver on a good day.
Either way, the diffs on my DEX210 and DEST210, are perfect and never need adjustment. I got pretty good at building diffs after having a Losi 22, and the B44.1, and doing it countless times. I feel the Durango diff is one of the best.
Old 02-01-2013, 08:26 AM   #504
zipperfoot's Avatar
I am trying to get my ride height around 29mm front and rear. Rear adjusts fine, but to get the front down to 29mm, I find the front springs have play in them. Around 2 or 3mm of up and down play (between the shock collar and bottom cup) when the car sits at 29mm. I have the 45mm Durango springs up front. I tried the springs that came with the truck, the Durango tuning springs, Losi and Avid. Did I miss something?
Old 02-01-2013, 09:03 AM   #505
Trader Rating: 19 (100%+)
Do you have the droop limited at all? I generally set the ride height and then adjust the droop screws to take up the slack. I know what you mean though, some longer springs of the correct rates would be nice.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 02-01-2013, 10:20 AM   #506
SMcD's Avatar
Trader Rating: 61 (100%+)
Adjust from there
We Shall See
The Track Raceway, RCRNV, JMR
Team Jacobs Racing
YouTube: looking for turtles entertainment
B6D, X-1 2016, T4 2014 VTA, SCX-10 II
SMcD is offline   Reply With Quote
Old 02-01-2013, 11:36 AM   #507
Trader Rating: 37 (100%+)
Im running Jonny5's setup on the DESC210, but in MM4. I'm thinking of setting up the DEST the same and starting there
jzwolen is offline   Reply With Quote
Old 02-03-2013, 02:21 PM   #508
mnracer's Avatar
So... Build question. The rear suspension rear hinge pin holder... My dex210 holder uses balls on the pins that go into and pivot in the rear holder. The dest210 I'm building has a supplemental page added to the manual that uses a rear pin holder that eliminates the balls on the pins. After assembly the rear arms bind with up/down travel with no shocks attached!! The kit includes the balls and pin mount like the dex210. I swapped them out to the original design and no more binding? What was the reason for the change? And why the poor fit???
Billy D
Old 02-03-2013, 11:24 PM   #509
zipperfoot's Avatar
Not sure about the binding, but my guess is they changed the pivot for strength. The pivot with the balls leaves less material aroun the perimeter of the mount (socket). With the pin going directly into the mount, there is more material around the pin to hold it in. It's stronger.
I broke the rear front hinge pin holder on my dex210 pretty easily. It broke right around the ball. Literally pulled out of the socket with the ball still attached to the pin.
Old 02-03-2013, 11:28 PM   #510
zipperfoot's Avatar
Thinking of trying 2 hole pistons, rm3, with a shorty pack. Anyone have any experience using 2 hole pistons on an outdoor dirt track? If so what springs and oil did you use?
Team Durango DESC410R Thread KostaG Electric Off-Road 12281 08-18-2017 09:10 AM
