Like Tree2Likes
Old 01-20-2013, 07:17 PM   #481
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Finished the build,and decided to go 1.3mm, 4 hole pistons with Avid Red Springs all around. All I can say is wow. The truck was planted on a dry, dirt track. I am really impressed with this truck. No weight, shorty pack mounted forward, and it was perfectly balanced. Stock turn buckles and ball cups. Everything worked great, no issues. Went through 3 packs of testing.
zipperfoot is offline   Reply With Quote
Old 01-20-2013, 08:12 PM   #482
ekt
ekt's Avatar
Originally Posted by Panic09 View Post
Well I bought a new body in hopes of making it work. The first one was badly chopped in the front to make the body posts work.
So here how it sits right now. Rear holes are lined up perfectly
But here is how the front ones look like
I m moving the front body post back and forth numerous times, trying various positions but it doesnt sit well. Any ideas?
I'll have a closer look at mine tonight. Pretty sure I just reamed the holes out and rotated the front body mounts to fit.
ekt is offline   Reply With Quote
Old 01-20-2013, 09:03 PM   #483
ajj
ajj's Avatar
Trader Rating: 18 (100%+)
I'm scratching my head looking at mine trying to figure that out. I'd say just do the fronts first, as once you actually drop the body on the post it'll be much closer than it looks now. So do the fronts as per the guide holes, then rotate the mounts to line up the back mounts as best possible and ignore the back holes if need be. Saying that, mine lined up fine with the guide marks on the body.
AJ
Associated SC5M, Hot Bodies D413, Durango DEX210, Durango DEX410, Mugen Seiki MBX7R
ajj is offline   Reply With Quote
Old 01-20-2013, 11:48 PM   #484
ekt
ekt's Avatar
I don't have a spare unpainted body, but did cover the rear holes with tape to try replicate your issue. I couldn't get it to look as bad as your picture, but you may just need to adjust your front body posts. The body needs to be put on front first.
Old 01-21-2013, 08:33 AM   #485
Panic09's Avatar
Well followed yr advice - cut the front holes first . Adjusted the body posts and now the front end slides in perfectly. Haven t done the rear body holes yet as the body now hits the rear shock tower. Need to push the body down really hard to make it go in but i don't see any other solution.
After all the attempts and tries I have done i think the above is the best option i have ,without badly hacking the body .
"I was so far behind I thought I was first"
MIKES RC WORLD(r.i.p) | TACOMA RC RACEWAY | FOUR SEASONS RC RACEWAY(r.i.p) | ISLAND RACEWAY
Panic09 is offline   Reply With Quote
Old 01-21-2013, 10:32 AM   #486
zipperfoot's Avatar
Take some pictures with the body off so we can see your set up. Take a pic from the top down so we can see everything. Also do some measurements like distance between towers , so we can compare. That's really odd, mine fits perfectly
Old 01-21-2013, 07:30 PM   #487
Panic09's Avatar
Here is a couple more pictures - length from tower to tower is about a foot
Old 01-21-2013, 07:51 PM   #488
ekt
ekt's Avatar
I'll check the distances on mine tonight, have you tried rotating the front body holders backwards/forwards?
Old 01-21-2013, 08:09 PM   #489
Panic09's Avatar
Yes did that already - even have a spare front tower and compared the holes were the body posts go - both towers are the same and holes are in the same place.
Well anyways I might be blind and miss something here...have a fellow racer who bought the same truck last week. Will check his car next weekend and will report
Old 01-21-2013, 08:39 PM   #490
ajj
ajj's Avatar
From the trailing edge of the rear shock tower brace bit to the leading edge on the top of the front shock tower on mine is 293mm. Looks like yours is 305mm?
AJ
Old 01-21-2013, 08:46 PM   #491
rcjunky1's Avatar
I'm looking to see how much interest there is in an aluminum chassis to use the buggy side pods. I had a couple buggy +8mm chassis made for some people to run at some big races and with enough interest I can do a run of chassis (+8mm, +8mmLW, SC and ST) but I'll need 25 pre paid to start the run. Pre paying will get a slight price break as well as buying multiple. I don't have final pricing yet but it will probably be around $75 plus shipping. If there is interest in a lightweight ST chassis like the buggy I'll need to get some testing done to make sure its strong enough. PM me with what you're interested in, I'm now just gauging interest.
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 01-21-2013, 09:05 PM   #492
Panic09's Avatar
Yup that's right - its 305mm...weird. That could be the issue here hhhmmm
Old 01-21-2013, 09:22 PM   #493
ekt
ekt's Avatar
I may have worked it out, looks like you assembled step 5 from your manual wrong.
The red circle, is how its supposed to look.
Old 01-21-2013, 09:54 PM   #494
Panic09's Avatar
Bingo! Woohoo...thats it. I messed up with the pivot links. Now the front tower is leaning backwards ,bringing the front body posts up. Thanks guys for taking the time to sort this out
Strange but my truck was handling awesome like this
Old 01-22-2013, 06:41 AM   #495
zipperfoot's Avatar
Good eye!
Team Durango DESC410R Thread KostaG Electric Off-Road 12303 10-17-2017 09:35 AM
