Like Tree2Likes
Old 09-07-2012, 02:58 AM   #286
DBL15's Avatar
Originally Posted by So*Cal AFDude View Post
Why no ball diff guys? They make the car handle so much better.
I will be honest mate I have never liked them because I don't think I have ever built 1 right either
So I just prefer gear diffs and can drive it just fine with them.
All my TD cars and buggys have gear diffs
C/O Coast2coastrc (www.coast2coastrc.com.au) SMC Lipo
Tekno Rc , Team Tekin , Panther-Rc , De Racing , Upgrade Rc , Team Triton rc , M2C clutches , Nitro X fuels
DBL15 is offline   Reply With Quote
Old 09-07-2012, 09:36 AM   #287
Moderator
ilanstylz's Avatar
Trader Rating: 142 (100%+)
+1
I have built plenty of ball diff's but they have been from AE rc's, and even though this one isn't much different I just can't seem to get it built right.... I did rebuild it and going to try it out again at the track tomorrow but if it fails again I'll be putting in the gear diff. I bought.....
B4.2 Tekin RS Gen2/Gen2 8.5
Tekno SCT410 HW SCT/HW 4700KV
TEKIN/AVID/T-BONE/
ilanstylz is offline   Reply With Quote
Old 09-07-2012, 10:17 AM   #288
Trader Rating: 19 (100%+)
Originally Posted by ilanstylz View Post
+1
Thorough break in is the key to this diff, assuming it is assembled correctly. I like to do an initial break in with a drill in my hands before I install it, then do it again in the car by propping one wheel off the table (with the other wheel touching the table and the front of the car pushing against something solid), then trimming the throttle so the free wheel spins. Let it run for a few minutes, tighten a small bit, then do the other side. Usually once per side is enough since I did the initial break in before assembly. My diffs usually outlast the outdrives in the buggy. I also use BFast diff balls and rings, but like the stock thrust assembly.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 09-07-2012, 10:20 AM   #289
Mini8 Menace's Avatar
Default Yea the screws were too tight
Don't over tighten the little screws mate
But yes it will be a bit tight until run in for 10 or 29 minutes or so then it should loosen up good
Did you use black grease ?
Yea I figured it out just after my post now it's like butter
TD DEX408, DEST210R, TA B44.1/upgraded to .2, XRAY T4 (in build), mini8, bashers
Airtronics LRP Tekin Revtec Orion Hi-Tec Futaba Savox Trinity CRGraphics
Mini8 Menace is offline   Reply With Quote
Old 09-07-2012, 11:32 AM   #290
So*Cal AFDude's Avatar
Trader Rating: 21 (100%+)
Maybe I should start selling assembled diffs. I have never had a diff go bad. It just slowly gets a little gritty after months and months of use. Like Jonny5 said, the outdrives usually need replacing before the diff needs to be rebuilt!
-Aaron Willming
~ Hobby-Pro USA ~ Viper-RC ~ IERC Raceway ~
www.IERCRaceway.com - www.Facebook.com/IERCRaceway
So*Cal AFDude is offline   Reply With Quote
Old 09-07-2012, 12:53 PM   #291
Anyone interested in a crush tube for the front wheel bearings: I used TD #712003 from the DEX410 along with (3) .2mm shims with a 5mm ID (same size as all readily available clutch shims, just need .6mm overall). Then you can tighten the front wheels down with no binding whatsoever. I also used the alloy hexes (on my SC) for a more rigid structure when tightening the wheels.
Old 09-07-2012, 01:06 PM   #292
Ceramic or carbide?
knowitall156 is offline   Reply With Quote
Old 09-07-2012, 01:14 PM   #293
Originally Posted by knowitall156 View Post
Ceramic or carbide?
I know that I found ceramic balls to be to smooth. And will cause a little bark. I go carbide all the way.
.02
-Aaron Willming
Old 09-07-2012, 01:55 PM   #294
.02
+1. Fred from BFast explained to me a while back that ceramic balls do not give enough friction, thus your diff setting needs to be tighter to prevent barking. Since then I have always used their carbide diff balls, and in my old AE cars I used ceramic thrusts. They go out of their way to ensure that the balls they supply are of the highest quality, and they have literally never let me down. I won't build a ball diff without their stuff for my own cars.
Old 09-07-2012, 02:01 PM   #295
Thanks guys
Old 09-10-2012, 06:29 PM   #296
Does the truck use the same springs as the buggy front and rear b/c i looked up the springs on petite rc it gave me the same as the buggy?thnx
Mike Richardson
At the track having fun with my friends
blingy is offline   Reply With Quote
Old 09-10-2012, 07:09 PM   #297
DBL15's Avatar
Yep sure can all the springs in the 1/10th range fit all cars. I swap and change from time to time.
Old 09-10-2012, 08:49 PM   #298
Trader Rating: 31 (100%+)
Anyone tried running this in MM yet? I just switched mine over but haven't tried it yet.
MBX6-ECO, B5m
Cspurlock is offline   Reply With Quote
Old 09-11-2012, 04:28 AM   #299
Smile
Boy that was shure smart on there part and i just spent about 70 bucks in springs so now it works out to 35 a set
Mike Richardson
Old 09-11-2012, 09:24 PM   #300
Moderator
ilanstylz's Avatar
Ok so I installed a gear diff and the tc5 ballstuds with jconcept/losi ballcups, gonna go to the track tomorrow and see if I can get more then 3 laps out of this thing. If my changes don't improve then its time for me to move on, I also think I know why my ball diff wasn't working correctly, I looked at all the pics and online videos of the build on one and the e-clip I was sent looks completely different so I will see if my local hobby shop has any and retry the ball diff again if I keep the rango.........
TEKIN/AVID/T-BONE/
Team Durango DESC410R Thread KostaG Electric Off-Road 12281 08-18-2017 09:10 AM
