Like Tree2Likes
Old 09-01-2012, 11:18 PM   #271
Moderator
ilanstylz's Avatar
Trader Rating: 142 (100%+)
Originally Posted by DBL15 View Post
How hard are you hitting the pipes mate as they don't pop off that easy at all on track
Did you build them with a drill or wind them on and off the full thread and use grease in threads ?
I had trouble with my DEX210 ball cups but this time round I built them as shown on TD site and they have been perfect.
Yes I used gear diffs in the 2wd from TD and just use grease to cover the gers don't fill it and it will take about 2 or 3 lipos to loosen right up.
Thanks I didn't even see that link on TD's website, I will give it a try and build it accordingly and if I still have issue's with them popping off I'll switch over to the tc5 and jconcept parts.......
B4.2 Tekin RS Gen2/Gen2 8.5
Tekno SCT410 HW SCT/HW 4700KV
TEKIN/AVID/T-BONE/
ilanstylz is offline   Reply With Quote
Old 09-01-2012, 11:18 PM   #272
So*Cal AFDude's Avatar
Trader Rating: 21 (100%+)
Originally Posted by ilanstylz View Post
Well since I haven't been able to sell my rango I decided to give it another shot. I ordered the tc5 ballstuds as well as jconcept and losi rod ends so we'll see if that fixes the issue I've been having with the turnbuckles popping off very easily...... Going to try the gear diff as well since for some reason I can't seem to build the dang ball diff correctly.......... Also upgraded to alum. toe blocks and going to try and dial it in next time out at the track using Randy Pike's setup as a guideline........
The Durango ball diff is hands downs.. The best.. Smoothest.. Longest lasting diff on the market. Follow the how to video on the Durango site, get the circlip on the right way, and do not over tighten. It will be golden! Hell I'll even build it for you and you'll fall in love lol
As for the ball cups, it's 50/50. I have 2 buddies who have nothing but problems. And myself and another friend have been running the same HD ball cups for 50+ packs and have only popped off 1 or 2 on hard hits.
-Aaron Willming
~ Hobby-Pro USA ~ Viper-RC ~ IERC Raceway ~
www.IERCRaceway.com - www.Facebook.com/IERCRaceway
So*Cal AFDude is offline   Reply With Quote
Old 09-01-2012, 11:29 PM   #273
Moderator
ilanstylz's Avatar
Thanks, I may have found the issue with my ball diff build so I'll find out next time I go to the track......... After reading up on the turnbuckle build it makes sense as to why mine have been popping off as well as why you should grease them and take a little bit out of the ends...... So we'll see, and I do agree that the ball diff is by far the best I've ever experienced as well, when it works lol.........
TEKIN/AVID/T-BONE/
Old 09-02-2012, 06:27 AM   #274
Suspended
Trader Rating: 7 (89%+)
Can you use the DEX210 chassis with the DEST210?
phathedrc18t is offline   Reply With Quote
Old 09-02-2012, 02:31 PM   #275
DBL15's Avatar
No mate it's to short
C/O Coast2coastrc (www.coast2coastrc.com.au) SMC Lipo
Tekno Rc , Team Tekin , Panther-Rc , De Racing , Upgrade Rc , Team Triton rc , M2C clutches , Nitro X fuels
DBL15 is offline   Reply With Quote
Old 09-03-2012, 04:06 PM   #276
aGeS1272's Avatar
anyone have any indoor setup tips as far as fluids and what fluid to run in the gear diff. here's a pic of my truck looking clean [IMG][/IMG]
Ian a.k.a. "Grill Skillz 2 Pay Tha Billz" I am not a RACER but I grill a lot..
aGeS1272 is offline   Reply With Quote
Old 09-03-2012, 04:10 PM   #277
DBL15's Avatar
Thumbs up
gear diff mate all you need is AE black grease or Losi smart diff grease but only enough to cover the gears do not fill it right up its not required
it will be stiff to start with but run it in for 2 or 3 lipos and it will loosen up perfectly and enjoy the next 6 months of not touching it as it stays perfect for a long time
have a look at Randy Pike set up to get a start mate and work from there
Old 09-03-2012, 04:15 PM   #278
aGeS1272's Avatar
where can i find his setup at?
Old 09-03-2012, 05:59 PM   #279
DBL15's Avatar
Originally Posted by Randy_Pike View Post
there you go mate
Old 09-04-2012, 06:05 PM   #280
Mopar's Avatar
Kinda doing the same also as the buggy except I'm using the new Durango rear hubs with vertical ball studs 2mm shim outside and 1mm inside. Also have on the Tresrey 2* anti-squat w/ .5* toe alloy rear arm mounts. Pistons are Ghea 1.3 x 4 hole front w/ 30wt oil, Ghea 1.2 x 4 hole rear w/ 25wt oil. Or use kit pistons and block off 2 holes with toothpicks and CA glue. Shorty pack 3/4 forward. Truck jumps great and steers awesome. A tad loose in the rear but still tightening the diff, may move bat back to the mid location. Also have Exotek alloy idle shaft and Tresrey motor plate and front bulkhead w/ pivot supports. A little red bling never hurts.
Mopar is offline   Reply With Quote
Old 09-05-2012, 02:38 PM   #281
DBL15's Avatar
Ok more testing done yesterday for our new controlled class of stadium truck
We will all be running 10.5 blinky mode.
I am running 81/29 on the above combo and it's so smooth to drive.
After another couple of hundred laps this trucks are just so much fun to drive
After 10 minute run my motor was on 50 degs
Old 09-05-2012, 02:40 PM   #282
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
If anybody needs shorty packs..have some in 4/s section.
kwiksi is offline   Reply With Quote
Old 09-06-2012, 03:57 PM   #283
Mini8 Menace's Avatar
Default Just build my gear diff
Just built my gear diff and I know it's a stupid question but this is my first 2 wd kit I've built and I'm just wondering if both out driver should turn smoothly or should the feel like a 4wd buggy/truggy diffs ???
TD DEX408, DEST210R, TA B44.1/upgraded to .2, XRAY T4 (in build), mini8, bashers
Airtronics LRP Tekin Revtec Orion Hi-Tec Futaba Savox Trinity CRGraphics
Mini8 Menace is offline   Reply With Quote
Old 09-06-2012, 11:38 PM   #284
DBL15's Avatar
Don't over tighten the little screws mate
But yes it will be a bit tight until run in for 10 or 29 minutes or so then it should loosen up good
Did you use black grease ?
Old 09-07-2012, 12:39 AM   #285
Why no ball diff guys? They make the car handle so much better.
-Aaron Willming
Team Durango DESC410R Thread KostaG Electric Off-Road 12281 08-18-2017 09:10 AM
