Like Tree2Likes
Old 08-29-2012, 03:09 PM   #256
snaketaco's Avatar
Originally Posted by Mopar View Post
kinda doing the same also as the buggy except I'm using the new Durango rear hubs with vertical ball studs 2mm shim outside and 1mm inside. Also have on the Tresrey 2* anti-squat w/ .5* toe alloy rear arm mounts. Pistons are Ghea 1.3 x 4 hole front w/ 30wt oil, Ghea 1.2 x 4 hole rear w/ 25wt oil. Shorty pack 3/4 forward. Truck jumps great and steers awesome. A tad loose in the rear but still tightening the diff, may move bat back to the mid location. Also have Exotek alloy idle shaft and Tresrey motor plate and front bulkhead w/ pivot supports. A little red bling never hurts.
Man sounds like you got a nice ride! I think I need one. Let us know how it works out.
My apologies for any errors in grammar, and spelling. It's a forum not a term paper! STADIUM TRUCK FOREVER!!!
Some day I want to be one of the guys with the cool T shirts and fancy stickers. I bet they get all the girls!
snaketaco is offline   Reply With Quote
Old 08-29-2012, 04:27 PM   #257
ABBOTT's Avatar
If I pick one of these up what parts if any look to be areas of concern. I only have the 410 so I am not familiar with any of the 2wd issues. I know there was some issue on the 210 early on with the rear inside ball stud mount. What was done to address that and is it still a weak spot on the new trucks?
SmacTrac / STL Dirtburners / Blaze RC
ABBOTT is offline   Reply With Quote
Old 08-29-2012, 06:07 PM   #258
Mopar's Avatar
Inside rear mount is not really an issue. Anything can break if preasured excessively. There are several companys making a piece that mounts the ballstud reversed directly above the stock location without the need to replace the tranny case. Only issue I've ever had with the 210's were the ball cups, I just automatically change to TC6 gold ball studs and Losi HD ballcups. With the truck you must use offset cups on the outside fronts so I use the Jcon ones there. Changing the rear arm mounts to alloy is only for the durability, note this change requires the pivot balls used on the buggy.
Mopar is offline   Reply With Quote
Old 08-29-2012, 06:12 PM   #259
Mopar's Avatar
This truck on the first runs already runs better than my 22t's first runs. I realize that is my opinion and am not critisizing the 22t's in any way. Everyone needs to run what they want and for me it's Durango. Just trying to stop the haters.
Old 08-29-2012, 06:14 PM   #260
Moderator
ilanstylz's Avatar
Trader Rating: 142 (100%+)
Will these work with the stock ballstuds, or do you have to buy the whole kit?
http://www3.towerhobbies.com/cgi-bin...?&I=LXBYTB&P=7
B4.2 Tekin RS Gen2/Gen2 8.5
Tekno SCT410 HW SCT/HW 4700KV
TEKIN/AVID/T-BONE/
ilanstylz is offline   Reply With Quote
Old 08-29-2012, 06:19 PM   #261
Trader Rating: 19 (100%+)
Gotta get the whole kit. The combo listed a few posts up is a much cheaper way to go, and I had great luck with the JC ballcups on my AE cars.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 08-29-2012, 07:11 PM   #262
aquamann's Avatar
my only complaint was the ball cups, but jconcepts cups and lunsford balls on the way, I also cut off the front droop screw tabs and put 4mm of spacers under the pistons on the front. I used my same set up on my buggy except for shock oils. I used the exotech rear hubs with a shorty pack 3/4 way forward. truck jumps and handles great I can definatly get in the throttle more than I could with my b4 i use to have.
TD DEX408v2, tekin Rx8 gen2, tekin gen2 1900kv
aquamann is offline   Reply With Quote
Old 08-31-2012, 12:31 AM   #263
DBL15's Avatar
Ok after more testing today all I would like is a little more aggressive steering but it's so much fun to drive
Have not had 1 ball cup problem at all after nearly 1000 laps of testing.
1 thing I am going to change though is take out the boosted 13.5 and install a stock blinky mode 10.5 rev tech in there. As we are running this class with 10.5 stock
Just wondering what gearing for this combo ? With a 81 spur. Thinking 26 or 27 piņon
C/O Coast2coastrc (www.coast2coastrc.com.au) SMC Lipo
Tekno Rc , Team Tekin , Panther-Rc , De Racing , Upgrade Rc , Team Triton rc , M2C clutches , Nitro X fuels
DBL15 is offline   Reply With Quote
Old 09-01-2012, 06:42 AM   #264
Trader Rating: 31 (100%+)
Has anyone noticed TD released some more RTR trucks, dest210 and desc210? They look pretty nice. Also for those who run yellow wheels, TD has them listed now, just out of stock, damnit!
http://www.team-durango.com/part-inf...artNo=TD510025
MBX6-ECO, B5m
Cspurlock is offline   Reply With Quote
Old 09-01-2012, 08:28 AM   #265
subaru_tech's Avatar
Trader Rating: 106 (100%+)
just bought a desc210.
is anyone making spurs for rangos.
or do we still need to drill out a a.e. spur.
need a 78 tooth
cant remember do you use ae pads.or was it , cut down the rango pads?
subaru_tech is offline   Reply With Quote
Old 09-01-2012, 08:33 AM   #266
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
need a 78 tooth
Durango...you'll see them here under option parts. RW also makes some.
http://www.team-durango.com/parts.ph...t=&scat=&show=
kwiksi is offline   Reply With Quote
Old 09-01-2012, 08:33 AM   #267
slow_jun's Avatar
Trader Rating: 14 (94%+)
need a 78 tooth
RW has for Rangos but not sure it has the tooth you need(69T,75T and 81T being the smallest unless they have updated their website) Tresrey has em that will allow you to use AE/TAmiya Spur but its a bit pricey..
http://www.tresrey-usa.com/tresrey-s...ex210-dest210/
TD site
Machine Spur
http://www.team-durango.com/part-inf...artNo=TD310311
drilling the wholes will likely cause more harm than good unless you have the right tool to do the job for it.
goodluck.
Mag 3 taon, tapos isalpak pa sa PAGMUMUKHA KO......... tagal....Deeeeymmm!!!
slow_jun is offline   Reply With Quote
Old 09-01-2012, 11:49 AM   #268
td is backordered.lol
i have a 8mm step drill.
just dont recall if you use ae pads or not
Old 09-01-2012, 06:00 PM   #269
Moderator
ilanstylz's Avatar
Well since I haven't been able to sell my rango I decided to give it another shot. I ordered the tc5 ballstuds as well as jconcept and losi rod ends so we'll see if that fixes the issue I've been having with the turnbuckles popping off very easily...... Going to try the gear diff as well since for some reason I can't seem to build the dang ball diff correctly.......... Also upgraded to alum. toe blocks and going to try and dial it in next time out at the track using Randy Pike's setup as a guideline........
TEKIN/AVID/T-BONE/
Old 09-01-2012, 11:06 PM   #270
DBL15's Avatar
How hard are you hitting the pipes mate as they don't pop off that easy at all on track
Did you build them with a drill or wind them on and off the full thread and use grease in threads ?
I had trouble with my DEX210 ball cups but this time round I built them as shown on TD site and they have been perfect.
Yes I used gear diffs in the 2wd from TD and just use grease to cover the gers don't fill it and it will take about 2 or 3 lipos to loosen right up.
Team Durango DESC410R Thread KostaG Electric Off-Road 12281 08-18-2017 09:10 AM
