Like Tree2Likes
Old 08-20-2012, 11:05 AM   #241
A friend of mine snap a shot of my Dest in action.
maxxi is offline   Reply With Quote
Old 08-20-2012, 08:30 PM   #242
aGeS1272's Avatar
Anyone have any idea on what gearing would be used with a 17.5 motor? My truck didnt come with a pinion and i have no clue on what pinion i would have to use. Spoke to one of them recaers at my track and he said i would need to change the spur to run 17.5 stock motors. I am lost. any help would be gladly respected...
Ian a.k.a. "Grill Skillz 2 Pay Tha Billz" I am not a RACER but I grill a lot..
aGeS1272 is offline   Reply With Quote
Old 08-20-2012, 08:39 PM   #243
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
You gonna run boosted or no timing "blinky"?
Boosted you can run the stock 87/20-21 to start.
Blinky I would go down on spur and up on pinion..not sure where to start. Maybe someone else can chime in.
Watch for temps..keep under 140 and top out at around 3/4 length of straight.
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 08-20-2012, 09:02 PM   #244
Trader Rating: 94 (100%+)
i used a 75 spur and a 27 tooth pinion and it runs perfect
redracerd is offline   Reply With Quote
Old 08-21-2012, 08:10 AM   #245
Is this better than Asso T4.1 Factory Team ?
lamav4 is offline   Reply With Quote
Old 08-21-2012, 02:57 PM   #246
DBL15's Avatar
has anyone weighed there yet? unless my scales are wrong i am 1880g with a short and no weight ?
what is everyone else running weight?
drove real nice and i did not have anytrouble with ball caps popping off either as i built them as directed on and off a few time with grease in the thread
C/O Coast2coastrc (www.coast2coastrc.com.au) SMC Lipo
Tekno Rc , Team Tekin , Panther-Rc , De Racing , Upgrade Rc , Team Triton rc , M2C clutches , Nitro X fuels
DBL15 is offline   Reply With Quote
Old 08-22-2012, 07:10 AM   #247
DBL15's Avatar
Well after a few hours of testing these trucks are really fun to drive that's for sure
I am less then 0.5 of a second behind my dex210 mod buggy with only a boosted 13.5 in the truck it fast and fun and has a heap of grip
Would like to know the weight of other guys trucks though please.
1880g = 3760lbs.
Great fun class though real happy and ball cups are fine as well
Old 08-24-2012, 12:28 PM   #248
Moderator
ilanstylz's Avatar
Trader Rating: 142 (100%+)
Taking the rango out to the track today, hopefully I'll have better luck with it this time around ;-)
B4.2 Tekin RS Gen2/Gen2 8.5
Tekno SCT410 HW SCT/HW 4700KV
TEKIN/AVID/T-BONE/
ilanstylz is offline   Reply With Quote
Old 08-24-2012, 01:07 PM   #249
aquamann's Avatar
Trader Rating: 14 (100%+)
finally got mine together and on the track last night and it felt great, i only had one issue of a ball cup poping of, tightened down my droop screws a little and reset my ride hight and then no more issues. I built the 3gear rear motor like in my dex210 and used the same set up other than shock oils and i had better grip and handling than the t4.1s on the track I was running with. I ran 81tooth spur, with a 30t pinion on a 13.5 boosted and felt great!
TD DEX408v2, tekin Rx8 gen2, tekin gen2 1900kv
aquamann is offline   Reply With Quote
Old 08-24-2012, 05:07 PM   #250
Mopar's Avatar
Ready to go for tomorrow.
Team Durango DEST210R thread-dscf0003.jpg   Team Durango DEST210R thread-dscf0004.jpg   Team Durango DEST210R thread-dscf0005.jpg
Mopar is offline   Reply With Quote
Old 08-25-2012, 05:29 PM   #251
Mine should be here Monday can't wait to start the build.
Hobbico
Trakpower Speed Equipment
Durango
Duratrax Tires
Futaba
Bagga is offline   Reply With Quote
Old 08-28-2012, 04:25 PM   #252
aquamann's Avatar
dont know how everyone elses truck feels but mine feels great!
Old 08-28-2012, 04:43 PM   #253
Trader Rating: 19 (100%+)
Kinda figured they were pretty good with as quiet as the thread has been. Usually it's only real busy if guys aren't happy.
Did you use the box setup? Got one ordered, just waiting for it to show up.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 08-28-2012, 05:24 PM   #254
DBL15's Avatar
Yep agreed truck is great no complaints and no issues at all
I used the same set up as my 2wd buggy for locations etc but went a bit heavier in shock oil apart from that what works for a buggy will work for the truck and I am running shorty as well.
Old 08-29-2012, 04:08 AM   #255
Mopar's Avatar
kinda doing the same also as the buggy except I'm using the new Durango rear hubs with vertical ball studs 2mm shim outside and 1mm inside. Also have on the Tresrey 2* anti-squat w/ .5* toe alloy rear arm mounts. Pistons are Ghea 1.3 x 4 hole front w/ 30wt oil, Ghea 1.2 x 4 hole rear w/ 25wt oil. Shorty pack 3/4 forward. Truck jumps great and steers awesome. A tad loose in the rear but still tightening the diff, may move bat back to the mid location. Also have Exotek alloy idle shaft and Tresrey motor plate and front bulkhead w/ pivot supports. A little red bling never hurts.
Team Durango DESC410R Thread KostaG Electric Off-Road 12309 10-25-2017 11:00 PM
