Team Durango DEST210R thread
#196
http://shop.towerhobbies.com/cgi-bin...&P=WR&I=LXKTJ5
This is the brand I use, not sure if this set has the correct size I have the whole set, and it is the best nut driver I have used. Walls are very thin, so I have never had a problem fitting in tight places. Worked on the stock wheels no problem.
#197
#198
I have one of the first trucks in the states so I believe mine has some parts borrowed as needed in time for a race I attended.
#201
I have a Trinity d3.5 10.5 motor going into my dest210r and need help on what to gear it at,anyone have a good starting point?
sac
sac
#203
They sent me back an email telling me they mailed me the screws. Took a couple days to get back to me though.
#204
Well, mine's done except for paint. THe only parts missing from mine were the 2mm x 5 screws for the pistons and bleeders in the caps.
#205
I finished mine yesterday, now I'm just waiting for the weather to improve to work on set up. I was missing the M2x5mm screws too. Picked some up at a local hardware store to use until the right ones come.
#206
Major Issue
Sup guys I need help and fast, I basically got the rango done. Wired up everything turn on the remote press the throttle and nothing. The motor turns etc but the wheels don't move. So I took the diff apart and I noticed that when I hold both end of the outdrives I can turn the diff gear with ease. I tried tightening down the screw as much as I could without overdoing it but still the same. So I took the diff apart and noticed that I couldn't get the thrust bearing out of the outdrive. After searching on the net it appears there are two different sizes of the thrust bearing washers, the instructions never stated this so I just put it on without checking. So I have no idea if I put them on correctly and now I can't even get the damn thrust bearing and washers out........ Anyone have any idea what I could have done wrong if I did install the washers correctly?
Oh and this isn't my first time building a ball diff, I've built many AE ones and the main diff. between the two are the thrust bearings............
#207
#208
Ur problem is ur thrust bearing most likely. The snap ring came loose and that is the result. Make sure u took out the snap ring and then the thrust bearing should come out. Once u get it apart, go online to team Durango site to the in the pits section and under tips and tricks there is a video of how to build it for a dex210. It is the same, so watch it and u will understand.
