I need better entry cornering. What to do?
I'm new all over again after a near 20 year departure. I now have a FT B4.1 and I feel it runs pretty well. I'm still not greatly acquainted with the Spectrum DX3S radio system I have. I feel like when I do give a little brake quickly before I enter a corner, it pulls around better. Should I be adding this braking to happen automatically via my radio system? Or should i be altering a setting on the car itself? Or both?
Thanks!
Thanks!
hope this helps
yah the buggies do need a lil tap of the brakes on entry to a corner to turn better ive talked to a couple team drivers and thats what they said (it needs a lil brake to get it around the corner quick really well) try messing with your camber a bit on the front you could put the front wheels in a lil in more and you could lower the ride height in the front a lil more, this is what i did to mine and i like it (its all about setting up the buggy to suit your driving and track style though)
hope this helps
hope this helps
Running a bit lighter shock oil in the front will cause the car to transfer weight forward quicker. And running a shorter camber link will improve steering response. But usually a little bit of drag brake helps quite a bit, but you will have to apply a little extra throttle in the air to keep it level.
I have yet to run b4, but in my 2wd vehicles, i get a little better turning when i have the ride hieght lower than usual. I also use tires in the back that have less traction in the corners so it starts to do a bit of a slide. This greatly improved my cornering. Hope this helps a bit.
Also, one more tip, in the corners i use slight throttle instead of pulsing it. I found that it helps make the turn a little smoother, and i was(somehow) able to get it to turn better when i used constant lower throttle then when i pulsed the throttle.
A little drag brake would be a nice place to start, around 5% or so. Give that a try. On the real tight turns I'll use the brake a little to initiate the turn, faster/wider turns, I won't use the brake.
I'd say, learn about the radio options, expo/endpoints, and put a little drag brake in the esc.
have you tried raising the roll center in rear?
dragbrake
