Castle Creations Losi 8ight conversion
I just purchase a Castle Creations Mamba 2650 brushless, programming card and a the Castle Creations Conversion for the Losi 8ight. I don't understand why the battery mounts that fit on either side are not big enough to handle any battery larger than a 2500 mAH. The motor mount is great but you have to stack the ESC on top of it. After spending $50 on it and getting it all together I got so aggravated that I decided to switch to the Losi 8ight converson. Much nicher fit and the battery tray will handle one 4S 6000mAH battery or two 6800 2S 7.4 volt batteries wired in series. It's too bad because I thought the best way to go would be to run all the same brand.
Weird i run a 2 cell 6000mah in each side for 4 cell total.
I've got a bunch of hours on it now with both my 10 year old and my 56 year old self running it. The only problem I've had is breaking a couple of tires lose from the wheel. A little super glue fixed that. The 4 wheel drive sure helps keep it under control. I'm glad I went with the LOSI Converstion it handles the 4s 6500mAh LiPo battery great and gives me a long run time.
I've got a bunch of hours on the LOSI 8ight with the 2650 Castle Creations and 4S LIPO Conversion and have had zero problems nad have not had to replace anything. I do have a new body that I'm going to need to paint for it. It is one fast machine.
do you want to sell your castle kit
I don't think I could find all the parts for the Castle Creations kit. Do you need the whole kit?
