Battery life
Battery life
i have an electric rustler and the vattery life is only 10 mins. max.
is this normal? I use a pirahna digital charger if that would help
thanks
thanks
That's pretty good, depending on the battery you have. Out of the Dynamite sport 1500mAh's packs I was getting about 7 minutes.
The higher the the number, the longer duration you can run for. Theoretically a 3300mAh should run longer than a 1500mAh.
