Old 02-09-2012, 07:50 AM   #1
jstump's Avatar
Send a message via Yahoo to jstump
Default Thunder AC6 Charger question
I am trying to figure out how to connect this to a 12v car or marine battery for remote rc racing where electricity isnt available. Anyone have any pictures on how its done?
Team AE RC10SC5M / RCConcept 120Esc/5.5/Savox/Proline/AirTronics MT4
Team AE B5M Lite/RCConcept 120Esc/5.5/Savox/Proline/AirTronics MT4
Tekno EB48.3 1/8 ebuggy, hobbywing esc, RCConcepts motor, Savox, Proline, Airtronics MT4
Tekno 410.3 4wd Sct, Hobbywing esc, Smc 4500 motor, Savox, Proline, Airtronics MT4
jstump is offline   Reply With Quote
Old 02-09-2012, 08:15 AM   #2
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
Before you read further, CONFIRM WITH YOUR MANUAL FIRST BEFORE TRYING ANYTHING!
from what I can tell based on the pics of the charger and what is included, there appears to be some sort of power port next to where the AC wire plugs in, correct?
That appears to be where you would run that one cable that has the banana plugs on it into a DC based power source like a power supply unit.
Now, since you want to hook to a marine battery, you would need clamps that the banana plugs would plug into, or just make a jumper of sorts that will plug into the banana plugs and have the clamps attached to that.
Again, CONFIRM WITH YOUR MANUAL!
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 02-09-2012, 08:27 AM   #3
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
The charger should have a set of battery clips and a cord with banana plugs at one end and a DC power plug on the end that goes too the DC power input on the side of the charger in the box .
The banana plugs go into the ends of the battery clips .Red wire too red clip goes on the + side , black wire too black clip too the - side of the battery .
Have you been ripped off by Brushless Hobbies ? If so go to BBB.org and file a complaint !
BashemSmashem is offline   Reply With Quote
Old 02-09-2012, 09:42 AM   #4
Tech Legend
Cain's Avatar
here is a better pic I found than what I was looking at:
So you should be able to make the connection using those clamps.
Old 02-09-2012, 10:19 AM   #5
joelwhite's Avatar
Trader Rating: 55 (100%+)
There is an output on the left side of the charger, Jurt to the right of the AC cord, also included in the box should be a lead with a connector just for that single hole with the aligator clips on the other end.
Ur good to go
But like Cain said,
read the manual!
HEART OF A HUSTLER RACING TEAM
Trick Graphics--see spdrac430 on this forum for all your painting needs
Team Pit Racers-Fastest Guys In The Pits!
joelwhite is offline   Reply With Quote
Old 02-09-2012, 06:46 PM   #6
Trader Rating: 14 (100%+)
second wire from the top on the right side of the charger plug into the big battery clips then plug into the left side of the charger. Hook up to your battery, you're done. The banana plugs fit right into the battery clips. Look at the left side of the clips. Self explanatory.
DuckStang is offline   Reply With Quote
Thunder AC6 Archy88 Electric Off-Road 9 01-06-2011 06:35 PM
Anyone try the Thunder AC6 charger? rcracenut Radio and Electronics 76 08-30-2010 09:55 AM
Li-Po Charger question EmRen Radio and Electronics 13 05-17-2010 02:29 PM
