Team Durango DESC210R
#1112
How do I post my setup sheet guys it's is too big. I would really like to share it since my setup feels amazing. I qualified second place in that a main in 4 by 4 short course. The track is small to medium sized clay with medium traction.
#1114
#1117
Some are having an issue with them popping out when running certain levels of anti squat /droop. If yours are not coming out it's not a real concern, but it they do you can contact Hobbico and they will send the longer shafts at no charge. Both our trucks have stock ones and have had no issue.
#1118
#1119
I am running 1.5 and about 3/4 drop and i keep losing the right rear!
#1120
so i got a 75 tooth spur that ive been told is the "key" and have read a few saying they are using it.
well i put it on and the smallest pinion i can get to mesh up with it is a 24t. thats for a ratio of 3.12 (spur &pinion). ill try it on the track but im a little hesitant. i think it may be geared to high.(med indoor clay track)
#1122
#1123
also guys, check out my build up of the kit on RCSOUP :
http://www.rcsoup.com/2012/10/team-d...-kit-build-up/
#1124
Saw the build up.. nice job. that Reedy sensorless should easily take that gearing, obviously no timing in motor to mess with :P twisted=geo?
