Help losi 2.0 e
Help losi 2.0 e
help ive got racing 2moro and my rear diff is slipping abit on take off and breaks. how can i fix it or shouldn't i run it?
What do you mean it's "slipping"? If it's skipping and clicking meaning the gears are too loose just take apart the diff and add shims to space the diff closer to the pinion gear. You want it maybe a hair notchy or one shim less than a hair notchy. Then you should be golden on gear mesh.
