XXX-T forum
#31
There is a bit more to it than that, not much but some.
To convert you need:
XXX-T Chassis - you can use the shorter chassis of the XXX but handling may suffer. Weight is not an issue.
Front A-arms
Front Spindles & Carriers
Front Axles
Front outer hinge pin and king pins
Front shock tower
Longer Tie rods Front and Rear
Rear A-Arms
Rear Truck Dogbones
Rear shock tower
Rear shocks (1.2 stroke)
*The rears from the buggy will be used on the front of the truck.
86 T spur (personal preference)
Body
Basicly - it's cheaper to buy a new truck
Front A-arms
Front Axles
Front shock tower
Rear A-Arms
Rear Truck Dogbones
Rear shock tower
Body
#32
thanks for all the input , guys!
i think there's too much cash needed for the conversion
#33
too late?
Do you guys think it's too late go get a Losi XXXT? Is there a newer kit? I want to go offroad for a change...
#34
No, I dont think it is too late to get the xxxt. Im sure associated will come out with another one before losi does, since it is a few years older. With that being said, I dont think they would tell you if they were coming out with a new one soon because they want your money now!!!
#35
Gearing
Well I just bought my first offroad XXX-T, and have a few queastions about gearing. Anyone have any recomendations on what spur/pinion gears to run? I'll be running a 19turn chameleon mostly and would hate to burn them up.
I notinced on teh losi website on some of the setup sheets, they have listed 24/92 and 22/78
Anyone know where I can get a gear chart or know the gear ratio to make my own?
Thanks.
Thanks.
#36
Hey guys, Just to let you know on the kit update thing. Listen, Companies like losi,associated,etc. have to keep kits coming out.
Its a good thing. Why? Because is gives you more integrated and hi tec parts better than the older truck. I race on-road as well as offroad and in both typs of racing kits are always coming out. Its just companies in competition with eachother trying to come out with an awsome car that kicks all other's ass's. Its just the name of the game my friends, live with it.
Frog-Ide say 22,if that dont work keep going smaller and smaller. With mods, You get your power from small gears. I race Mod 13 turn double xxx-t and I run the Stock Spur with a 16t pinion. In all my cars (Unless its a dramatic change in the track layout) I stay with stock spurs and just mess with the pinion.
#38
The xxx-t's come with 2? I never got 2. I got one red spur
#39
I just got bacl from the lhs and all they had was the 88tooth spur gear. Since I dont have a manual for this truck I dont know if there is another. I had a 24 tooth pinion and my stock motor was smelling burned so I went to a 21 and it got better.
#40
What color was the spur? Red is the stock one.
You got to go down on it. I ran a 18 for my stock motor.
#41
Red it is.
#42
K, Thats the stock one I use that one. Put a 18 on it for a 27 turn motor and ur good!
#43
I have several motors, what about for a 19 or a 9 turn double?
The same gear or lower?
#44
ide run 9. But Your time with a mod is gonna dimish fast! Run a 15 or 16 with the 9. I run 13 turn double and i run the 16, I my ideas dosnt work keep goin lower gears. Mods get their power from small gears.
