Novak GTB2 reviews?
i like the fact that its $99 not the $219 that orion and tekin want. im on a budget for racing. i would like to be able to drop 200 for a esc but i need 2 of them so thats 400 or 200 for 2 gtbs.
just on amain the low profile one says its great to 10.5 but under the motor limit it says any novak 540 motor
Company Representative
We have a new GTB2 with X-Drive, which is 15.00 more, but offers additional features.
Yes. The standard HS and LP HS versions are exactly the same. The size of the HS is what determines the motor limit for the product. We sell the LP HS separately for those customers purchasing the standard version to take advantage of the 3.5T motor limit and then converting to the LP HS, if necessary.
Tech Legend
are you having issues with your MMP in your sig?
the MMP through its CHEAT feature will have the timing options I believe you are looking for.
As for price, assuming you buy 2 of them, if you are a tower member you can get them for about $107 a piece (buy 2 at $127, use $40 discount code, now $107 shipped)
thats not to say there is anything wrong with the novak gear, I really enjoyed my havoc's when I got them. I am just thinking since you already have one MMP and assuming no issues, you could keep it all in the family for a cheap price.
Another option is the Speed Passion 2.0 line.
The GT2.0 LPF is a great ESC and can be had for about $90 right now:
http://www.speedpassion.net/us/produ...8802LPFb&c=ESC
I think the Pro version you can use in SCT as well and is $125.
with the LCD Programmer that you and buy the sister hobbywing version (you just update the firmware to SP and it works) for about $20, you get all the boosting, timing, turbo, etc. features you want.
If I wasn't invested in my MMP stuff that I also use in 1/8, I probably would have all these ESCs.
great thanks. i was also looking at the sc version that has the x-drive and that had timing right? can you put the LP HS on that also and run timing in a buggy. im not worried about the normal HS on my truck or sc since there is plunty of room. i would just like the option of having timing if i want it
The Tower discount codes will save you an equivalent amount of money regardless of the products you select...
The speed control works great in a 4x4 Losi SCTE Ten Short Course truck too, it is powering this Tekin 4000kv 4 pole motor no problemo. I'm pretty impressed with the GTB2. Many people are spending a lot more money to do the very same thing. I've been using it in this configuration for quite a while too and been through many races including the Colorado State Championship like this without a single issue.
