Losi diff rebuild kit
Is it possible to get Rebuild kit for my Losi XXX-T MF.
If so, does anyone know the part#.
i dont beleive there is a kit, but you can buy all the parts and lube speperatly
Exactly, how do you go about rebuilding a diff?
I'm sorry for this broad question, but I've had my truck for about 2 years now, and I have not done this yet. I'm pretty far up on the racing level now, and doing good, and am not just getting to change the setup on the truck (XXX-T).
Any help would be greately appreciated?
take it apart first. you may need new diff rings. sometimes you can just turn it over and use the other side.
you need thrust bearing, diff balls, grease for diff balls and a different type for the thrust bearing. check all your diff bearings.
sometimes even the diff screw has to be replaced. check everything and then order your parts. follow the directions in the manual.
Registered User
well....actaully there is a kit...comes wiht the screw....washers...bearings things liek that...but its just not ALL the parts...just the common parts that break or something like that...MAKE SURE TO GET THE MOLDED THRUST BEARINGS!! i hate stinking on them stupid lil balls on the washer
