Old 01-22-2012, 04:09 PM   #1
Trader Rating: 17 (100%+)
Default 540 vs 550
hi guys, was wondering what is the motor type preference for a losi scte. 540 or 550 can size and why
thanks ralph
ralph brunt is offline   Reply With Quote
Old 01-22-2012, 04:12 PM   #2
DoogieLee's Avatar
Trader Rating: 42 (100%+)
Usually 540's
mainly because now with the 4 pole motors, you can get a smaller (540) motor that will push it very well, without the extra weight, since the Losi is a heavy truck already.
Kevin 'Doogie' Lee
\m/ SCTE 3.0*XB8e\m/
Qualifiers are just organized practice...
DoogieLee is offline   Reply With Quote
Old 01-22-2012, 04:24 PM   #3
zipperfoot's Avatar
Trader Rating: 16 (100%+)
thanks ralph
Says on the website that 550 size suggested. The reason being is more torgue from the longer can, easier to power a 4wd. Also a 550 will run cooler even with the extra load of pushing a heavy vehicle. Not sure what the new 4 poles will do for you. I would stick with what works, but I am sure someone will chime in and tell you they run a 540 with a 1/10 scale esc and have no problems, but I think heat will be an issue.
If slow is fast, how come I'm still slow?
zipperfoot is offline   Reply With Quote
Old 01-22-2012, 04:31 PM   #4
Grandturk's Avatar
Lots of folks using the 540 sized Tekin and Castle 4-poles. I still ur the 550 Novak ballistic. It's got enough grunt for me.
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 01-22-2012, 04:33 PM   #5
DoogieLee's Avatar
Not the case at all, I run a Castle 1410 3800kv which is a 540 4 pole motor, geared with a 16t on my Losi SCTE and I usually temp at 140-150 after an 8 minute main.
Same with the new Tekin Pro 4, 4 pole motors, they move these trucks quite well, and if they run hot, you've got another problem.
Kevin 'Doogie' Lee
Old 01-22-2012, 04:34 PM   #6
Originally Posted by DoogieLee View Post
Usually 540's
i saw that most every body was running the 540 can and it comes with the 550 and was getting ready to upgrade from the stock is why i asked... is heat not an issue? like zipper said?
Old 01-22-2012, 04:35 PM   #7
thanks, i see that the 550 is a tad cheaper any reason why?
Old 01-22-2012, 04:37 PM   #8
DoogieLee's Avatar
What motors are you looking at, specifically?
Im assuming you have the RTR Losi, that motor was meant more for use on 3s, as its a bit of a dog on 2 cell.
Its the same motor as the Castle 1415 2400kv, and the esc in the RTR is a rebadged Castle MMP.
You can either throw a 3s in your truck and watch it come alive, or go with a smaller 4 pole motor and watch it rip on 2s.
Kevin 'Doogie' Lee
Old 01-22-2012, 05:06 PM   #9
thecman26's Avatar
Trader Rating: 98 (100%+)
thanks ralph
Been covered about a thousand times on the Ten-SCTE thread.
Run whatever you want, no real advantage either way really... Just pick one and go fast! 550's are great and the next generation 540 4 poles are great too, just make sure your esc can handle it!
Chris Keen: Viola, Kansas
FT T4.2,T5M, B5M FL, Kyosho RZ6, TLR 22 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 01-22-2012, 05:22 PM   #10
thanks for your help
Old 01-22-2012, 06:46 PM   #11
thecman26's Avatar
Anytime! I personally think my current set-up is hotter than sliced bread Tekin RX8/Pro4, I went with the 4000 just because I don't need crazy HP but I still have it on tap whenever I pull the smile lever! That is also known as the throttle trigger on my DX3R!
Old 02-09-2017, 06:05 PM   #12
Jcbdnny's Avatar
Might be a silly question, but can I use a 2s Lipo with a 550 motor? Thought I heard that a 550 would only work with 14.8v so not sure what to believe...
Thanks in advance
Jcbdnny is offline   Reply With Quote
Old 02-10-2017, 10:36 AM   #13
As far as racing goes in these parts only 2s is allowed. So I've never seen anyone run a 550 on anything but a 2s.
greener74 is offline   Reply With Quote
Old 02-10-2017, 11:45 AM   #14
kevinatfms's Avatar
Thanks in advance
I run 2s all the time on my 550 Trackstar 4.5. You wont have a problem.
Screwing with r/c's since 1996
powerwerx.com
kevinatfms is offline   Reply With Quote
Old 02-10-2017, 05:51 PM   #15
Jcbdnny's Avatar
Freaking awesome, looking at a 3900kv motor for one of my franken-trucks and was wanting a tad more umph than what I had, I just didnt want to have to invest in more batteries.
novak vs castle brushless ridinloudprod Electric Off-Road 63 11-15-2011 02:26 PM
Ballistic 5.5 vs Velineon in slash 4x4 2fst2c Electric Off-Road 17 05-02-2011 03:28 PM
Novak 550's Roar approved Failedabortion Electric Off-Road 81 04-06-2011 11:18 AM
