Transmission HELP!!!!!!!!
Hey guys, my Losi Desert Truck's transmission is being lame. I press full throttle, the motor and everything spins but not my wheels. BTW, i put a castle creations 5700 motor combo.
1.inspect to make sure the wheels arent stripped out.
2.Make sure that the pinion is on the spur gear fully and that the spur gear isnt stripped out.
3.Open up the transmission and inspect the gears.If i had to guess i would say your idler gear is stripped out.
Have someone at your lhs check it out to see what they think.
Good Luck
Good Luck
Hit every nail on the head!! /\ If it does end up being your idler gear stripped, pay the few extra $$$ and go with all metal gears... Avoid this problem in the future...
the idler gears are fine.
If all the gears are fine then it has to be the diff. Either it's loosened up too much or the 5700 fried it. Try tightening it back up and see if it still feels smooth. If not throw some new rings, balls, and a thrust bearing in and have at it!
