Like Tree1Likes
Old 11-02-2016, 05:11 PM   #61
shadaloo's Avatar
These things are badass, wish it would of hung around and become a race class..
shadaloo is offline   Reply With Quote
Old 11-02-2016, 06:39 PM   #62
Originally Posted by 67StingrayJ View Post
Zinergy,
how did you go to a 17mm configuration? Can you post photos and list part numbers? I'm interested in seeing how everything went together.
I learned the hard way. The first kit I bought was for the SCTE since many parts will work on the SCBE and TEN-MT. The SCTE comes with 5mm axles, the TEN-MT has 6mm axles so that kit didn't work. Then I found the kit for the 6mm axles, which I could only find directly from the manufacture. No other stores seem to sell it but they all sell the SCTE kit.
http://www.m2cracing.com/product.sc?productId=333
I'm not sure if the SCBE has the 5mm or 6mm axles but if it has the 14mm hexes like my TEN-MT does then I would guess they are the 6mm. I think the SCTE has 5mm axles because it has the 12mm wheel hexes. The kit is pretty straight forward, remove tires, remove wheel hexes, remove axle pins, place adapter over axles, put the pins through them, lock pin in with small screws that come with the kit. That's it.
Zinergy is online now   Reply With Quote
Old 11-03-2016, 08:36 PM   #63
fyrstormer's Avatar
What, are they discontinued already?
Check out Fyrstormer's Garage in the Chat Lounge.
fyrstormer is offline   Reply With Quote
Old 11-03-2016, 09:27 PM   #64
67StingrayJ's Avatar
Does anyone know either way what size axels the SCBE comes with? How about what size hexes?
It doesn't sound like Losi is playing the "compatibility" game with it's wheels. Long term, for whatever reason I feel like the right move is to switch out the axle stubs with something else.
67StingrayJ is offline   Reply With Quote
Old 11-04-2016, 06:03 AM   #65
14mm is a weird size. Very limited in selection. 12mm is standard 10th scale, 17mm is standard 8th scale so both will have tons of choices.
Old 11-04-2016, 07:58 AM   #66
egalsim's Avatar
Trader Rating: 39 (100%+)
Just use 17mm, better wheel selection and more durable
Associated RC10B6 / Kyosho Optima / Associated Tekno SC8e / Awesomatix A700exl / Serpent Cobra BE 2.1 Rally / Kyosho MP9 Tki3.5 Tekno V4 / Team C TM4 / Tamiya Bruiser
egalsim is online now   Reply With Quote
Old 11-04-2016, 08:23 AM   #67
Im assuming these work.
https://www.amainhobbies.com/mip-sct...p16150/p525889
Planning to use those (already have them from my mip ebuggy coversion)
kki000 is offline   Reply With Quote
Old 11-04-2016, 01:55 PM   #68
Like i said the first kit I bought was for the scte and it didn't work because the scte had 5mm axles. So just make sure the kit works with 6mm axles. Unless you have aftermarket axles.
Old 11-17-2016, 07:41 PM   #69
Shumzz's Avatar
Default Ten-SCBE 2.0
Here is my TLR TEN-SCBE 2.0
Fully loaded TLR hopups it has it all plus the MIP Bypass1 kit
Link for pictures
https://goo.gl/photos/NdomRdFGRPKxANQN7
https://goo.gl/photos/RxYKHzcyBfTk4Rpi7
Last edited by Shumzz; 11-17-2016 at 07:47 PM. Reason: Don't understand how to post picture
Shumzz is offline   Reply With Quote
Old 11-22-2016, 07:41 PM   #70
shadaloo's Avatar
Is there a way to get a body like this onto a Tekno? I love how these look, but I sold my Losi SCTE 2.0 and run a Tekno SCT and EB... I really want a SCBE, or Yeti, Wraith, etc type body...
If anyone has any ideas or tips id appreciate it! haha
Old 11-22-2016, 08:25 PM   #71
fyrstormer's Avatar
Funny, I was just wondering if it would be possible to fit the SCBE body onto one of Losi's RWD SCT chassis.
Old 11-22-2016, 08:38 PM   #72
egalsim's Avatar
Well, if it fit on my Kyosho Mp9 tki3, then it should fit on the Tekno:
Old 11-22-2016, 08:45 PM   #73
shadaloo's Avatar
Any idea on what mods i would need? wasnt sure how it hooked up really.... don't see normal body posts or anything
Old 11-22-2016, 08:50 PM   #74
egalsim's Avatar
You may have to modify the rear shock tower to accommodate the hinged mounting cage. Basically, you will need to put the cage together first and put the panels, then fit it to your buggy and see where you will need to mount the hinge that goes onto the rear shock tower. After that, you can mount body posts to the front and the body should just go right on.
Old 11-23-2016, 12:06 PM   #75
shadaloo's Avatar
hmm ok, i like how it looks and im shocked that the scbe isn't more popular... I guess ill just have to keep looking and see how it actually mounts up. Was hoping someone who had a Tekno already did it so I could see if it is easily doable.. lol.
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
ROAR has banned a sct tire that's barely released Kent Beal Electric Off-Road 324 12-07-2011 12:55 AM
Wanna get into SCT 1/10 Ghost44 Rookie Zone 18 11-10-2011 07:19 PM
TeamLosi(Junk or NOT!) Come Vote xsxracing Electric Off-Road 130 07-14-2008 01:53 PM
