droop and its suspension handling characteristics - need help!!? RC8Be
Ok I have a RC8Be that I love, but it get squirelly coming out of turns under power.
I am a good driver, with a light trigger finger. I am just curious as I set droop to a set length as per a driver set up sheet.
Now I would like to make adjustments.
Something tells me if I take droop out of the rear (less suspension travel) I will gain more rear bite and traction roll less, but I could also see it going the other way as well (with the exception of body roll)
please advise thank you
(should I consider adjusting anti squat) - if so which way do I go
We have found moving the rear camber link up on the tower helps put the power down better on corner exit. This will lower the roll center also.
Downstops limit how far the suspension arms travel downward, which determines how
far upward the chassis rises. This affects the car’s handling (due to effects on camber
and roll-center) and the ability of the tires to “follow” the track. The effects may change
with the type of track and/or amount of grip available. Downstops are a very sensitive
adjustment, since they alter weight transfer, and all aspects of chassis performance are
affected: braking, acceleration, jumping, traction and rough track handling.
More suspension travel (lower downstop value) makes the car more responsive but less
stable; it is also typically better on a bumpy track or on a track with slow corners. This
allows the chassis to “pitch” rearward or forward more under acceleration or braking
(respectively), which results in more weight transfer.
Less suspension travel (higher downstop value) makes the car more stable and is
typically better on a smooth track. This prevents the chassis from “pitching” rearward
or forward too much under acceleration or braking (respectively), which results in less
weight transfer.
It is very important to have the same downstop settings on the left and right sides
of the car.
EFFECTS OF DOWNSTOP ADJUSTMENT
FRONT DOWNSTOPS
Higher downstop value(arm is higher, less
travel)
• Decreases front chassis upward travel on-throttle
• Less rearward weight transfer
• Better on smooth tracks
• More on-power steering
• More responsive in direction change
Lower downstop value(arm is lower, more
travel)
• Increases upward chassis travel on-throttle
• More rearward weight transfer
• Increases rear traction on corner exit
• Better on bumpy tracks
REAR DOWNSTOPS
travel)
• Decreases rear chassis upward travel off-throttle or
under braking
• Less forward weight transfer
travel)
• Increases rear chassis upward travel off-throttle or
under braking
• Less stable under braking
• Increases steering on corner entry
• More turn-in
REAR ROLL CENTER CHARACTERISTICS
Higher• Increases on-power traction
• Use to avoid traction rolling at corner entry
• Use under low-traction conditions
Lower• Decreases rear traction into corner
• Increases steering into corner
• Use to avoid traction rolling mid-corner and corner exit
weight transfer.
of the car.
FRONT DOWNSTOPS
travel)
travel)
REAR DOWNSTOPS
travel)
under braking
travel)
under braking
• More turn-in
