Old 12-25-2004, 03:25 PM   #1
Angry T-Maxx and new Picco .21 problem?
I recently, well yesturday, got a Picco .21 for my Maxx. Its the drop in motor. Basically I ran it idling for a tank, it ran mint didnt get really hot up at all. I let it cool then went and ran tank 2 going slow around the driveway and after like 5 min stopped and when I went back it has trouble at Top Dead Center. Its reallt tite and wont really turn over but with the glow plug removed there isnt a prob. The only thing is that it will start but stalls when I give it gas and pulls the pull starter cord and dies. Any ideas? I hate the idea of the engine being fried or something.
Kevin67 is offline   Reply With Quote
Old 12-26-2004, 07:48 AM   #2
Rich Panganiban's Avatar
Trader Rating: 70 (100%+)
Kevin67, what you describe is pretty normal. If you were running a brand new engine when the temperature outside was cold then it will be extremely tight at TDC. That is what you want because the engine will run good once broken in. As far as the engine dying, that is normal too. The carb settings from the factory are for break in, meaning the settings will be pretty rich.
Just a couple of suggestions:
1. Don't run your engine when it's cold outside (less than 60 degrees). Use a hair dryer to warm up the case, then start it up.
2. Run it up and down, the street or parking lot, for most of the tank getting it to around 200 degrees, then shut it off. Don't let it run out of fuel, and make sure it's not at TDC when it's cooling. You may need to lean it out a little to get it to run at 200.
Hope that helps.
Rich Panganiban is offline   Reply With Quote
Picco P-3 Running problem vnmsgt Nitro Off-Road 5 05-15-2008 10:22 AM
Picco P-3 running problem. vnmsgt Onroad Nitro Engine Zone 4 05-15-2008 06:40 AM
Picco P9R problem jeff1 Onroad Nitro Engine Zone 1 02-06-2008 07:22 AM
R40/JL PICCO RED DOT/OFNA STARTERBOX PROBLEM?? bxpitbull Nitro On-Road 3 08-22-2007 12:47 AM
NTC3 and Omega Picco problem somedude Rookie Zone 1 05-08-2004 11:27 AM
SEO by vBSEO 3.5.0
