Losi 8ight converte chassis Q?
Chassis question about the Losi 2.0 converted with the Tekno conversion. On ends of the hingepins, they go into little black inserts that are capped by the hingepin braces. What's the difference in those inserts? What does it change?
Those inserts are used to change the angle of the hinge pin.
this way you can adjust anti-squat and toe-in on the rear, for the front you can change kick-up.
always make sure you put them in so the car is equal left and right.
check out a off-road setup guide to find out the effects of the changes.
