Car troubles
Old 12-21-2011, 11:16 PM
Mxer59's Avatar
Trader Rating: 114 (100%+)
Default Car troubles
I have a OFNA Hyper 10sc 4x4 SCT. I'm running a Novak Havoc Pro, Ballistic 4.5 Motor, Savox 1258, AMB Transponder, Glitch Buster, Specktrum Sr3000 Reciever. Now my issues is I'm getting about a lap and in the same spot maybe 2 or 3 times in a 8min race I'm getting shut offs just for a split second. My car is temp. 120 on motor and about 78 on Esc do it's not a thermal issue. I switched out sensor wire just in case. But still a no go I'm kind off narrowed down to my remote or a batt is bad, is it possible for a batt to cause this issue because my thunder power no shut down my Tiger lipo in my car is the only thing that I notice the issue, it's a 5300mAh 50c.
Mxer59 is offline
Old 12-21-2011, 11:36 PM
How is the steering? on mine i switched out the spectrum for a sanwa 2.4 module and all is fine now. Some odd reason with rtr radios on the drivers stand it caused glitcheson throttle and steering until i switched
mugenlife is offline
Old 12-21-2011, 11:57 PM
Mxer59's Avatar
Steering is fine its a Airtronics M8 with specktrum
Module. The thing is that everything worked great till last week
Mxer59 is offline
Old 12-22-2011, 08:23 AM
Mxer59's Avatar
Anybody else got any tips could it be the batt
Mxer59 is offline
Old 12-22-2011, 08:52 AM
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Why not borrow a battery from somebody? It will help you eliminate one possibility. Are you 100% sure all your connection are good? Are you using bullet connectors between motor and ESC, ditch them if you are. Did the problem just start or has something changed and now you notice the problem?
Yeti AS3 is offline
Old 12-22-2011, 10:04 AM
Mxer59's Avatar
I have 3 batt I have to identical batt so I think it's one of them. It does it on one of my identical ones. Everything is re solderd there's no bullets connectors. I will have two double check by running each batt to pin point it I guess
Mxer59 is offline
Old 12-22-2011, 10:33 AM
84 GT 5.0's Avatar
Trader Rating: 26 (96%+)
Sounds like your glitch buster went bad. Try another one.
84 GT 5.0 is offline
Old 12-22-2011, 10:45 AM
Mxer59's Avatar
Even if it happens once or twice in the same exact section after a step down
Mxer59 is offline
Old 12-22-2011, 11:31 AM
dirtman71's Avatar
Well it sound like a bad conection somewhere...probably a bad esc....does everything go dead, steering and motor?
seems like comming off the step jump jars the electronics just right. Not sure how the glitch buster works but try to remove it and see what happens.
Looks like you need to remove one piece at a time and see what fixxes it if possible, borrow another esc if posible.
if its just your motor cutting out check the soder conections...they can be a pain to get sodered good.
dirtman71 is offline
Old 12-22-2011, 11:41 AM
Mxer59's Avatar
Esc is brand new havoc with x drive I had my buddy who's good at soldering resolder the deans and motor. It does it real quick but I have steering I believe.
If I run my thunder power batt it never did it
Mxer59 is offline
Old 12-22-2011, 04:38 PM
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
try a different receiver like an SR3500 or an SR300 and see if you still have the same issue.
Cain is offline
Old 12-22-2011, 05:03 PM
Jerm13's Avatar
Trader Rating: 36 (100%+)
you need to be sure you still have steering. If you dont have steering, it could be the BEC in the speedo or the wires from the speedo to the rx. If you do, it could still be the speedo but also could be your rx. I would try and re-bind the tx/rx and then try a new rx.
Jerm13 is offline
