weird crackleing
Old 12-09-2004, 09:26 AM
Default weird crackleing
i have had my hpi mt 2 4wd and haven't had any problems with it until now.
i was zooming it around like everyone does untill i noticed when i reached about half its max speed it started to crackle, the faster i went the louder it got. i thought it was my break pad rubbing so i loosend it of but it still makes the sound, any ideas???
BoneHead is offline
Old 12-09-2004, 04:59 PM
never lift's Avatar
did you check your slipper clutch . or it just might be a gear mesh problem
never lift is offline
Old 12-09-2004, 05:33 PM
j240z's Avatar
Don't forget to check the clutch shoes too!
Do engine rpms go up but no increase in speed?
Did the pipe get disconnected?
j240z is offline
Old 12-09-2004, 06:07 PM
never lift's Avatar
forgot to mention check your clutch bearings
Old 12-09-2004, 06:43 PM
corvettecrazy's Avatar
did you break a tooth off one of the diff gears?
is anything stuck in the dogbones. (remember the cards on bkie wheels) is something wrapped around and flapping?
corvettecrazy is offline
Old 12-10-2004, 03:08 AM
Smile
thanks for your reply, i will check the stuff u told me to.
thanks
BoneHead is offline
Old 12-10-2004, 09:00 AM
VONEREFLEXR's Avatar
Sounds like the diff, normally the slipper won't make that noise.
VONEREFLEXR is offline
