Team C USA
#31
thank you joe,
rctech needs threads like these also, the access to factory teams, and representatives is what makes this site great. the problem is, it is a fine line between access an advertising....i am lenient on this stuff more than i should be, but i felt i needed to deal with the other threads....
enjoy your day and thank you for your understanding..
#32
well i had a extra plastic front shock tower that i cut the middle section out of so the mounting holes would line up with bumper support. drill 2 holes on top and use longer 3mm bolts to go through block, shock tower into bumper support. use 2 Teamc turn buckles and 4 captured ball ends. drill 2 hole in the curved section of chassis. adjust turnbuckles to fit.
#34
Maybe just too slow or something lol.
regardless, great mod and looks like it would last forever
#35
not so much 1/8 scale tracks but we do have pretty good size jumps. its more like michigan cold winters and our indoor tracks are 40-50 degs which makes the plastic a little more brittle. Comin up short on a big double or triple would break the kick plate. have not broke one since i made the mod
#36
#38
You'd have to ream the ID of the spur. Go slow until it fits. Shave or mill the OD of the slipper hub to 1.22 inches. You can also shave the OD of the slipper spring perch to .266 if you want to use the V2 slipper spring. I use a 25mm screw with two 3mm locknuts with NO FLANGE with the nylock side facing each other cuz that end fits inside the center and holds the slipper plate tight and flat. Insert slipper plate, put 3mm screw into a dremel, and run it across a file until Im at the correct size. Homemade handheld lathe.
#39
you want to move block up...
OK then - a shame we can't see the other thread any longer, it was becoming a good read.
I really like wheelin these cars, the 2wd has heaps of rear end grip, so much so I need to find steering. And the 4wd is fun and planted on our track.
I had my T4 and TC2 (with the Evo longer chassis) out on the weekend. Was able to generate more steering on TC2 Evo by removing some droop from the front suspension.
JFuel11 - I see you've sanded the steering blocks and shimmed them 1/2mm in your setup. Do you mean half a mm or 1 to 2mm?
Did you sand the bottom and bring the steering lower or sand the top and shim up higher?
Also has anyone found good replacement diff thrust race balls for the T4 and TC2?
#40
#41
Team C new factory driver Ian Haley managed a clean sweep at Gladstone's very tough track.
Qualifying Round 1:
Right from the first laps of practice with the granitic sand type track still slippery it was evident that the T8T was really on pace. The only Truggy to run 15 laps and with a lap time some 0.8 clear of the rest round 1 was in the bag.
Qualifying Round 2:
This was a challenging round with others beginning to match the pace it came down to a clean 10 minute run and thanks to the very economical JS Racing TX 521R and Nitro-X HP 173 fuel, no fuel stop.
The consistency 0.64, round 2 won and with it TQ
Qualifying Round 3:
The track had begun to break up badly in the 30 degree sunshine, and so with some minor setup changes to the T8T
and a change from the VP Pro medium flexx tyre to the Low flexx another round was won.
A Main Final:
Haley`s ever reliable combination and one less fuel stop than others, thanks to the JS and his partner Debbie, quickest with the fuel gun! Team C has its first major win in Australia.
1) Ian HALEY - VP PRO, NITRO-X, JS RACING / TEAM C T8T
2) Shane FREIBERG - Mild to Wild Rc, M2C Racing, Hobbies Aus. Hotbodies AKA
3) Ben ANDERSON - RC-MAD / Southern Cross Hobbies / Mugen MBX6T OS
4) Rob CAMPBELL - RRCCC / Losi 8T 2.0 / JS 23
5) Steve BOYER - GMRCCC / Chucky Motor Sports / Mugen MBX6T
6) James HOWE - MRCCC / Mugen MBX6T / Alpha
7) Gavin MILLS - GMRCCC
8) Corey ANDERSON - MRCCC / Hong Nor / Novarossi
9) Sumo SURASAK - RC-MAD / sumo`s glass / MBX6T / Werks b6
10) Scott HUMBERSTONE - GMRCCC / Mugen MBX6T / Alpha
Great job Ian!!!!!
Qualifying Round 1:
Qualifying Round 2:
Qualifying Round 3:
A Main Final:
Great job Ian!!!!!
#42
Way to go Ian! The T8T has obviously passed the final pre-production testing. We can't wait for it to arrive in the US.
Qualifying Round 1:
Qualifying Round 2:
Qualifying Round 3:
A Main Final:
Great job Ian!!!!!
Qualifying Round 1:
Qualifying Round 2:
Qualifying Round 3:
A Main Final:
Great job Ian!!!!!
