what do you clean with
#16
I use a toothbrush, paint brush, rags, paper towels, cotton swabs.
To clean the RC after bashing or racing at the track, I use the paint brush to remove the dust and debris.
Once a month, I disassemble the RC, to change the shock/diff oils, make an inspection of the parts, and do a complete cleaning.
Sorry if my english was bad.
#18
I use a combination of rags, detailing brushes, a tooth brush and Q-tips to clean my truck, and a scribe to clean out the screw heads. I use a basic green cleaner (personally I use 7th generation cleaner because that's what is on hand at my house) and after a good clean I put a light coat of WD-40 on the chassis to help it resist dirt buildup.
i strip the electronics down. spray the entire thing with simple green, air compressor it and whip the rest off with any type of shop towel. I personally do this process again. then i take wd-40 and spray it everywhere and air compressor it down and whip everything off again i only do this one time. then reinstall your stuff!
#20
#23
-after every race, I strip all electronics out of vehicle, spray on Kal-Gard degreaser and O'donnell speed wash, aggitate with stiff bristle paint brush, let sit for maybe 2-3 minutes, then rinse off with hose
-then completely dry vehicle (compressor and towels), then spray WD-40 over entire vehicle
-after vehicle dries again, spray KG prep n shine over entire truck
-use warm water for body and dry with rag
#24
#25
#26
I believe in taking good care of your belongings but all these responses seem like overkill. Although, I'm going to guess in the long term that caring for your vehicle like this would enable you to have a 4yr old car that looks brand new. I'm just not convinced that cleaning this often and this in depth is a necessity for such results.
I don't think it's to increase the life of the car. Not for me anyway. After a full tear down and rebuild assessing what needs replacing or tweaking. The car will run really well on the track. Especially important for big races.
Pulling a car apart brings to light problems like bent hinge pins, rust in the pin holders, shot bearings, any hidden cracks, need to re-shim, sticking of arms.
I don't care what set-up you have on your car, it's not going to be dialled if you have any of these issues. You can't tell any of these things by just looking at the car in one piece with dirt all over it.
If you're 100% into racing and getting good results this is path of the course.
Plus, if it's your thing, having a clean and prepped car is all part of racing Zen.
#27
That's cool for you to do what ever you want. For sure. But...
#28
Simple Green, spray it all down but stay away from electrics, Use tooth brush and a rag. Spray again, use compressed air and help along the dirty spots with thar toothbrush, when its clean spray it down with wd40 and lightly use air to spred the wd40 not blowing it all off but not leaving it a dripping mess. Then wipe the exposed parts with a rag... put her back to bed! Body simple green and water be carefull on onside not to mess up ur paint! Go easy on inside of body!
#29
Once you start getting faster, you'll be hungry for tricks/tips to make your car quicker and handle better. The better a car handles, the less likely it is to be hard to control over jumps etc.. and thus less crashing.
Enjoy.
#30
As 1 stated, cleaning a car is the best occasion to check if everything is fine. Most of the time I just need brushes but when it's really dirty then I disassemble the car. It doesn't need so long in brushless, especially on a JQ.
The more you disassemble the car and see what is wrong the more you understand how it works and learn to anticipate. You don't need to do it too often, but it's also part of the pleasure IMO. Just to have a nice free movement of the parts, the car has to be clean.
