Lipo saddle question
I would like to order saddles for my future ZX5 FS2 but I would like to find 2s saddles(per small packs) for a 4s total setup
is that possible? or is it always 1s per saddle?
with some research I found that maxamps is making 3s saddles but I would like 2s per saddle
thanks
Karl
thanks
Karl
some saddles is written 7.4volts is that per saddle or after it is connected in series?
im so confused. I am trying to find 7.4v per saddle to get 14.8volts total for 2 saddles
any help would help
thanks,
karl
any help would help
thanks,
karl
The closest thing I can think of is the new shorty packs as initially used in the Losi 22. Or even some 6v LiFe packs.
You would need to modify the car for these to fit as they are longer than lipo saddles.
http://teamassociated.com/news/lates...4V_Shorty_LiPo
Guys guys guys! all cars can handle up to 6s if tuned properly
im talking about a 1500kv 540 motor.... on 4s! thats not many rpm
but a lot of run time with much less heat
thank you 1 I will take a look at these shorty packs! I am able to fit 2 shorty packs in my SC-R but they wont fit in my RT5
too bad turnigy does not make shorty packs lol
14.8v(4s) x 1800kv motor = 26640 rpm
550watts of power / 14.8v = 37.16 amps of heat (heat is bad)
7.4v(2s) x 4600kv motor = 34040 rpm
550watts of power/ 7.4v = 74.34 amps of heat (heat is bad)
the 14.8v setup will run 3 times longer than the 7.4volts setup...
why wouldnt it handle 4s?
the FS/FS2/FS2SP wont fit a 4cell saddle pack. already have to search for one around 25mm thick. just isnt enough room to fit one if u did manage to find a 4cell. between the center brace and the body the clearance isnt there.
Cooper, I found a way to make it fit
each saddle is consisted of 1s in parrallel. I will take it appart to connect it in series so every saddle will be 2s but with 1/2 the mAh capacity
then I will be able to have a regular saddle on 4s
what do you think?
what do you think?
