solid diff
solid diff
im looking for a solid diff like what the crawlers use but its for a more realistic rc build not looking for a crazy expensive one just one that look semi realistic. i have found like just empty shells but none of the stuff that goes into them.
Technical term for what your asking for is a "live axle"
Sounds like what you want is only going to be found in the crawler world. Look at axial replacement parts. They have a shafty, scx10, that the pumpkins (ring and pinion carrier between axle tubes) look fairly realistic. Losi's crawler axles look more like real crawler axles, not standard (IE; wouldn't look right on a car), plus the worm gears are super low geared, and many of the other crawlers are MOA (motor on axle) so they're not going to look right. HPI has a shafty too. Otherwise you're stuck going the custom route.
alright thanks for the input guys
If you do a build that is less crawler and more off-road, up-date us with some pics please. Sounds interesting
yeah im looking for like a more of a truck like ranger body, im planning on building a 2wd road truck that goes really fast and looks semi realistic, how many post before i can post links?
