Team Associated RC8.2e Thread
#3616
Tom, you'll be cutting it close keep wheel spin to a minimum. If the track is wide open smooth flowing/rally style do not drive the car deep into the corners/lift early and allow the rolling resistance to slow the car down (literally drive without using brakes). This will be the most fuel efficient drive habit to pick up on.
#3617
Anyone know if the new Vertical Spindles are lighter that stock?
#3619
How heavy is your RC8.2e? What changes would you recommend to reduce weight?
#3621
Zero Force Team Asso RC8.2e Bearing kit set
Zero Force Team Asso RC8.2e Bearing kit set (18pcs) (ZF-B11014)
Zero Force Team Asso RC8.2 Bearing kit set (18pcs) (ZF-B11005)
www.rcgoods.com
www.rcgoods.com
#3622
I would not recommend using only 2S Lipos. You can use two matched 2S lipos in series which makes 4S. That is what I'm doing. On 2s only you would need a 5000Kv motor like the Novak Ballistic 4.5t 550 but Novak doesn't recommend to use this. Short Course 4x4 motors may work but really the weight of this vehicle is pretty high for 2s.
#3623
My RC8.2e weighed in at 3610 gms with my heaviest batteries (2xNano-Tech 5600-50C hardcase). With my two shorty batteries (2xReedy 4000mAH-60C) pushed to the front it weighed in at 3425gms. So not too bad really for 8th scale. My weight distribution didn't change too much between the batteries and was 48/52 roughly so I could loose some weight in the rear somehow. Maybe the rear Carbon tower. With the Reedy batteries I was nearly 50/50 left to right. I would need to add about 50gms to the reciever box to really get it super close with the NanoTech batteries. Adding a little weigh to the front will also help the front/rear balance. So a nice 4500-5000mAH battery should be pretty good for this car for static balance. I beleive the ROAR rules use the 3200gm minimum spec so I really don't need to shed much.
What weight saving ideas do you have? Which upgrades do you recommend for reducing weight?
1) Carbon Towers
2) Ti turnbuckles
3) Lundsford hinge pins
4) Vertical Spindles
5) custom changes?
1) Carbon Towers
2) Ti turnbuckles
5) custom changes?
#3624
#3625
What Speedo are you using? I would stick with an 8th scale specific speedo for this application like the Tekin RX8 or similar.
#3626
4wd short course is already putting a heavy load on 2s batteries with a 4000 to 4600kv motor.
If I were you get all the e-buggy guys together to petition for 4s. or not run e-buggy and start running something else like 2wd mod or 4wd mod buggy.
#3627
Double check their rules. e-buggy is very heavy for 2s and will be very hard on the motor, esc, and battery. Lower voltage means more amp draw on top of a car that already weights 3600 to 4000 grams means that ESC's will be popping and batteries puffing. I WOULD BE
#3628
Change #1 is to an appropriate tire (ask a local fast guy if at a track, if in a friends backyard do some internet research). Tire is about 80% of set-up.
If it is rough, you may want to consider increasing the ride heigh a little bit.
After tires and reight height (super easy, super fast to do, free), look-up a guide on how to set-up a car, then refer to the manual on how to perform those adjustments. Hudy has a nice guide, as does JQ THE Guide.
#3629
Can you post a link? Something like you suggest would be very helpful.
#3630
Google turned up this gem, seems on par: http://www.competitionx.com/rc-racing/rc-tuning-guide/
Hudy set-up guide: http://www.google.ca/url?sa=t&rct=j&...oj71mC71DY-3EA
This is a lot of reading material about setup.
