Old 06-20-2013, 04:31 AM   #4771
I think you may just be a victim of overtightening the screws. I know its easy to do and I'm not being critical. Start over with a new housing and spur then all new orings. I've been keeping all the shims where the manual recomends and haven't had a problem. Just use lots of grease on the orings and grease the whole gasket both sides. Take your time tighten the screws evenly and you shouldn't have an issue.
homershoots is offline   Reply With Quote
Old 06-20-2013, 04:48 AM   #4772
schumacher_will's Avatar
What gearing for a Tekin T8 2050kv motor
Will PirozzI
Team Associated B5/ B5m/ B44.2/ T4.2 Jconcepts/Reedy/Lrp
Xtreme Hobbies Deer park NY
Island Raceway & Hobby
schumacher_will is offline   Reply With Quote
Old 06-20-2013, 05:44 AM   #4773
I run 16/46 with no issues, things get a little warm when I start adding teeth. The 16/46 gives nice bottom end and a nice top speed. You don't run 1/8 at that indoor track at island do you? If you are and are running 3s mb 15 pinion.
Old 06-20-2013, 05:59 AM   #4774
tom2tone's Avatar
Trader Rating: 98 (100%+)
Originally Posted by slashracer111 View Post
I would suggest building the diff as David Joor suggests. One blue shim on the outdrive externally, then one blue shim on the inside behind the sun gear.
The plastic spur gears have a tendency to warp if used a lot or over tightened. You may want to try a new spur to see if it helps.
My new stuff has been fine, but if it's an older kit, you may want to sand your diff case down so that it makes equal contact with the spur gear on all areas.
I seal the diff gasket off with Associated clear grease. It seems to work really good from my experience.
What are the blue shims and where do I get them? I did put on a new spur gear, my old one had worn uneven. Whats the best way to sand the diff case? Thanks for your reply!
I did back off and loosen the screws hoping that it would help. I may just try again and see where I get. Is it best to use the black grease or the green slime? I have both and usually just use the green slime on the shock orings. Thanks for your help!
TEKNO EB48.3 / ET48
HB D413 / AE T5M & B6
Tekin / AKA / Hitec / SMC / Futaba
Trains and Lanes Racing http://tandlracing.com/
Dunn Raceway Park http://drprc.com
tom2tone is offline   Reply With Quote
Old 06-20-2013, 06:06 AM   #4775
Just use some really find grit sandpaper on a flat surface (countertops table whatever) just put the housing face down on the sandpaper and run it over the sandpaper in a figure 8 motion. Don't go crazy putting lots of pressure only sand lightly till the sealing surface looks uniform.
Old 06-20-2013, 07:16 AM   #4776
tom2tone's Avatar
Ok thanks, I'll give it a try.
TEKNO EB48.3 / ET48
Old 06-20-2013, 07:47 AM   #4777
Bburns's Avatar
Originally Posted by heavyjeffd View Post
What parts #'s did you use?
3x asc89076. Need the small rod ends from kit.
2x lns1555 5x55mm turnbuckle
2x lns1570 5x70mm turnbuckle
Bburns is offline   Reply With Quote
Old 06-20-2013, 10:37 AM   #4778
Croland1980's Avatar
I have recently done the camber link mod as well. Instead of modifying the stock tower. I ordered the carbon towers (front and rear) from PSM Option Parts in Germany. They are already made for the camber link option. Also provide added upper shock mounting holes as well. The rear already comes with the "0" holes drilled.
Shipping was really inexpensive. Right around $8 and I had them in my hand with in a week from Germany to Pittsburgh.
Front tower costs around $36.
Rear tower is about $38.
I am unable to post links. But if you go to www . psm-shop . com you will find them by searching for RC8 and the front is the "SPECIAL" tower.
Sponsors: Tekno RC |Dialed-Hobbies |Short Shift Paint Workz |McCullough's Raceway
EB48.2 : ET48 : NB48: B44.2 : C4.2: T4.1 : B4.1
______________________________________________________________________________www.rolandrc.weebly.com
Croland1980 is offline   Reply With Quote
Old 06-20-2013, 11:13 AM   #4779
Awesome! I'm gonna get those towers for sure.
These towers , the link mods , lundsford punisher ti turnbuckles and hinge pins , tekno v4 conversion , lrp active8 and ix8 (tekin stuff in ft car) this should all make my rtr a badass. If it handles better than my ft car I will put new ft big bores on it and race that while I upgrade the ft car to the same specs.
Old 06-20-2013, 11:53 AM   #4780
boudin4evr's Avatar
Trader Rating: 18 (100%+)
so no front camber link mods on FT RC8.2 towers?
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 06-20-2013, 02:07 PM   #4781
Originally Posted by Bburns View Post
Finally got my camber link mod done. So much better.
Front
your cone washers are backwards front and rear
point faces out always...less resistance against the vcbs and hubs
ATX
bohdi is offline   Reply With Quote
Old 06-20-2013, 05:05 PM   #4782
Bburns's Avatar
I fail to see how this matters. I've been running these cars since the original rc8e and it doesn't make a difference. The cones don't move.
Old 06-20-2013, 07:48 PM   #4783
hey guys thinking of getting this buggy but dont know what are the known issues with it i heard that someone broke there chassis in half is that common or just a random thing?
what parts should i keep handy what have u broken on yours? what problems have you had?
thanks for the help
traxxasrockhead is offline   Reply With Quote
Old 06-20-2013, 07:54 PM   #4784
Suspended
Trader Rating: 23 (100%+)
thanks for the help
Broken chassis? Intresting.. It is an aluminum chassis so yes it can and will bend if it has a hard enough hit. A nitro truggy flew off a triple went on the other side of the track and bent my chassis. Got it fixed, but breaking I can not see happening. I haven't had any problems yet.
Airtronics - Carburant Racing - EZ Customs - 92zero Designs
Team G Racing is offline   Reply With Quote
Old 06-20-2013, 08:11 PM   #4785
I have an rtr with 60 hours on it and have not broken a single thing. As far as spares go you need front hub bolts and bushings, the blue plastic shock bushings, some bearings are good to have, diff orings fluids and gaskets and lots and lots of tires lol. This a totally solid car for sure just don't expect to bash the Crap out of it and not break something. If you have a racer mentality and just want to pound laps and go racing this is the car for you. If you want to go to the skate park and jump ridiculous things mb get a vorza.
Team Associated RC8Be Thread kaisertrip Electric Off-Road 7463 01-10-2017 12:39 PM
Team Associated RC8.2 Factory Team Kit is coming ShagNastyEk9 Nitro Off-Road 9159 06-08-2016 04:12 PM
Critters Raceway - new indoor dirt offroad track in north jersey G_WORD Racing Forum 9591 12-07-2011 08:13 AM
Tags
problem, rc8.2e rtr, servo
