need help with ezrun 60 amp esc
i just got a 60 amp esc for my slash with a 5.5 turn motor and it wont let me go full throttle when at a dead stop. it stutters for about 2 seconds and then starts to go. need help been looking cant find solution.
i forgot if try full throttle when the car is off the ground its perfectly fine.
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 42 (100%+)
Did you use the stock pinion from your slash??? If so you are WAY over geared for the 5.5...also you should go into the settings and turn the punch up from the stock settings,and turn the timing down..default is the 15* setting on timing drop that to about the 7.5* setting..is it the stock pinion and spur your using, or have you re-geared for the 5.5??
its the stock pinion gear and sput gear
what size pinion and spur gear should i use
and i know its not the right motor, im going to get a 8.5 turn motor
I am running a 5800 Kv in my scb with no heat issues, just have to find the right ratio and keep the timing on the low side
yes i set the esc to the tx, i even switch the remote to see if that was the problem and it wasnt so it has to be gearing.
i forgot to add that when i lift the rear tires off the ground and go full throttle it works perfectly. but once i put tires on ground is when problem starts
sensorless I have one of the esc's he has and a 13.5 version of his 5.5..being sensorless if you over gear it too badly it WILL cog on hard starts..especially with the timing and punch at factory settings while over geared.
You have this esc and motor correct?
batteries may not be up to the job , that combo will probably thermal shutdown pretty quick pushing a sct , 120a speedy would have been better if you must run a 5.5 , as previosly mentioned i'd go to 8.5 . cheers
they didnt give me that motor they gave me a 5.5 t motor called "victory"
as Gogi mentined the battery may also be contributing, what are you running for battery??Because the 5.5 DOES demand some serios amperage flow.
