novak vs castle brushless
#16
started to look at Hobby Wing products. I really like their ESC and motors, they are decent.
I have a few races on all mine no issues at all. Much better performing than my MMP. My only problem in my 22 last race is figuring how to keep the front tires on the ground
#17
) : I fu cked up. I did not get the 4 pole version. atleast it dont say 4pole on it.
#19
no they make a 6900kv
Castle Creations 1/10 SCT 4-Pole 1406 6900KV Motor on ebay
#20
Tech Legend
Trader Rating: 51 (100%+)
In the 1406 series of motors Castle has a 4600, 5700, 6900, and 7700kv 4 ploe motors. A little bit longer in size is the Castle 1410 series and has the 3800kv and is what alot of guys run and bash in both 2wd and 4wd SC's. The 4600kv or the 3800kv SC motor are the two most popular for racing purposes and have usable power on the track.
#21
yeah, the one I got is the 6900kv cm36s....starting to think I made a bad choice in motors ) :
#23
sometimes people listen to the wrong people to hard to figure out who is right on a web site.you have to go back and read some of there post to see if there being honest or just messing with people.
#24
well i wanted a fast motor, I took into consideration of what everyone told me. as the thread states though novak vs castle. I was in between those 2. as i stated somewhere above ill most likly just enjoy this for a little bit then sell it with my batterys and go with a low kv higher battery 3 or 4s But I wanted a higher kv motor now since i have 2s batterys and if its 2 much for what I need I can just turn it down on the esc. but if i ever want to race someone or something I know i got the power just need to change settings in the esc. But pretty sure I should of went with the 4 pole motor.
#25
I can't find the website to give you the link but with gearing you want to gear your truck so you are @ WOT (Wide Open Throttle) in the fastet part of your track. Your motor will run more efficiently and cooler giving you better run times. If you tweak with your Punch and Torque controll you will have a truck that is less likely to spin out on you and has the top end speed for your straight.
#26
Yeah I got a usb cable and downloaded the software for my esc to do all the tuning on my computer ( :
#27
Have fun programming. If you need a hand you can pm me. I'll give you a hand.
#28
Alright, Thanks. well my motor showed up yesterday did a quick hook up. and it did not seem to run that good. Hopefully today my 4mm bullets will show up so I can charge my lipo's and see how that works.....One thing is, I hear a clicking noise when I run it even slow cant figure out where it is coming from somewhere in the back end. If i get a chance today ill take a video and maybe someone can point me in the right direction. I got my pinion gear pretty tight so im petty sure its not that slippen. my cluch is as tight as it goes, plus it does it when the back tires are off the ground.
#29
