Dynamite Fuze 3300kv
I have a Dynamite fuze 3300kv in my BLITZ runs great so far so good. just woundring what the timming is on this motor and how much timming the ESC with the programming card can add. wright now I'm running 18/88 gear does that sound about right
Nobody knows! Well how do they run conpaired to other motors
the Fuze 3300 motor is a good, solid motor and great for 2 wheel drive SC. I had the 5800 and never messed with the timing or the program card simply because it ran good right out of the box - so I can't answer on the timing.
Do you race???
Are you just bashing around home and vacant property???
Why do you want to add timing??? IF it's for more speed, you can more than likely go up on the pinion and get that result - but be sure and watch heat!
Do you race???
I'm starting to race and getting the hang off it. I'm only on tracks.
I have the same motor and esc I never messed with the timing . I use a 21-22 pinion and 87 spur and it runs good.
i ran this combo dynnamite 3300/Fuze ESC in my losi 22 before i got my viper system. with the programming card it gives you the option of timing.
the soft timing felt less punchy and didnt have the straightaway speed
the auto setting was the smoothest setting
the hard setting would cog at low speed low throttle, it heated up, but man it would keep up with the majority of the 2wd buggies.
