Car just looses signal while driving
#17
I had the same exact problem last weekend, at it sounds like you actually troubleshot it yourself
my servo was pulling to much juice, it would cut out just like you described. I put a spektrum cap on the receiver and i was good.
you said you put a cap on the receiver and it worked fine for 2 heats
you may need to run an external BEC like the castle one.
#18
#19
My truck was doing what you are descibing but i hadn't recently replaced any parts. My truck did it most on one particular battery, Relaces a det of deans on that bat and ESC and cleared up all my issues. This may not help your issue but I found by braiding the motor wires i was able to get better range out of my set up.
