how to set up a sc truck using scales
never used scales before looking for some insight on how to tune with the scales
I think the general process is to use the scales to balance the chassis first. Balance left/right is more important that front/back. left/right should be 50/50 and front/back, could be 35/65 or 30/70 for a 2WD, but closer to 50/50 for 4WD.
Once that is done, you can then choose the correct springs, oil, pistons, etc.
Info
I was wondering what the ratio was supposed to be.
I've got a few questions?
I'm having problems getting repeatable results. I could take the truck off the scales, then put the track back on an get different results.
Do you set the truck on the scales then push it down to get it to ride height?
Cross weights? I've got the chassis balanced, w/ a string and a level, side to side. The truck flew great and was much better than before. I then bought some scales, found out the string method got me within a few grams.
BUT, the cross weights were off, the heaviest wheels were on the opposite side from each other. So I used the shock collars to even them out, the truck then flew like it did before, not flat.
I tried using weights to adjust the cross weight but could never get it close enough, and w/ the different results everytime I weigh the thing, I'm losing faith somewhat.
Could one of you gurus chime in?
I recommend reading this entire thread:
http://www.rctech.net/forum/electric...ber-links.html
I forget exactly where the scales sub-discussion starts, but there is a lot of good tuning information throughout the whole thread.
Here is a good summary of how to go about tuning:
http://www.rcshortcourse.com/forum/s...ad.php?t=23083
If you can't see that for some reason, I'll put it here. It references the thread I put above, too.
Originally Posted by nytryder
#1 Balance the chassis. If you don't have scales, use a string tied to the centers of your bumpers and hang it from the middle(for left/right balance). Find and mark the center point of the chassis by measuring from front axle to rear axle. Place chassis on a piece of round pipe and balance it front to rear. It should balance as close to the centerpoint as possible, with it having a very slight rear weight bias. Mine balanced about 1/8" behind center.
It is important to balance the chassis both front to rear and left to right with battery and all electronics installed. Try to mount your receiver next to your esc to add weight to the right front of chassis.
#2 Balance your shock springs to your chassis WITHOUT OIL (without pistons preferred) at ride height. Make sure there is zero binding anywhere in the suspension or you'll be spinning your wheels here.
All other suspension adjustments hinge around this! DO NOT SKIP THIS STEP!
#3 adjust your shock oil/pistons to the type of terrain you're running on.
Once you get your suspension to handle the bumps properly, then you can move on to how it handles in the turns.
#4 Choose the right tires for your track
#5 Adjust your camberlinks and camber/toe. I suggest starting with the Traxxas "slayden" setup as a baseline setup. you will be tuning with these instead of moving shock locations around.
#6 Adjust swaybars as necessary.
#7 adjust your diff fluids as necessary.
Refer to this link for details on each step. [url
http://www.rctech.net/forum/electric-off-road/519561-tune-camber-links.html[/url]
First, you need an adjustable leveling board and four scales.
I suggested you buy this for the price:
http://www.lefthander-rc.com/catalog...oducts_id=1638
1) Mark each scale Front Left, Right Rear, etc
2) Level the board and set scales on each corner.
3) Aline each scale so that the tire is in the center of the scale and remove vehicle.
4) Turn on the scales
5) Set vehicle on the scales.
6) Press down on center of vehicle to set corner weights after rebound
7) Read and write wheel weights.
Left to Right chassis weight should be 50/50 for off-road
Front to rear start-out at 35/65 2WD
IMO this is wrong. Having bias to the left or the right isn't the worst thing ever, contrary to popular belief. However, you must get the cross weight correct, which may or may not mean wedging the chassis depending on the track. Indy cars have been using asymmetrical setups on road courses for more than two decades for good reason - there are more turns one way than another.
If you aren't leveling (or at least checking to make sure it's level) your scale board every time you use it, you are wasting your time.
Every race car I've ever scaled I've done the same way, RC or real.
You level the scales.
You put the chassis on the scales.
You bounce the chassis slightly on the scales to settle things out.
You note the weights.
You bounce the chassis again.
You compare the weights to the first reading, and if they are different, you try to identify why.
You make adjustments, and start over again until you are happy.
Some of us do an extra step and do some math after the first reading....this is not that hard! If us oval donkeys who only turn left can figure it out, anybody can.
Please see Heavy Duty's post (post #6) I was referring to. steps 2 & 5 have steps that apply specifically to the ssclcg slash 4x4, and not all rc's.
Checking alignment, setting ride height, checking corner weights, and then REPEATING that process after you make an adjustment is pretty standard.
