Old 08-14-2011, 09:08 PM   #1
mdowney's Avatar
Trader Rating: 21 (100%+)
Default Best way to cut carbon fiber?
I want to play around with making my own CF top decks for my off road kits (Tebo is running them on all of his cars so I thought it would be fun to experiment with how they effect handling).
What is the best way to cleanly and precisely cut CF at home without expensive, hard-to-find tools?
Any tips on where to buy good CF would also be appreciated.
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 08-14-2011, 09:13 PM   #2
jsinclair's Avatar
I would think a high speed jig saw with a fine tooth blade would do a decent job, it works for fiberglass. Just remember to wear some gloves and a dust mask, its quite sharp and you don't want to be breathing the dust.
jsinclair is offline   Reply With Quote
Old 08-14-2011, 09:14 PM   #3
jamie ferrell's Avatar
Trader Rating: 3 (80%+)
dremel tool with cutoff wheel....carbon cuts like butter!
Jamie Ferrell
www.jamairpaint.com
JamAir, Radiopost, Kyosho, Tekin, AKA
jamie ferrell is offline   Reply With Quote
Old 08-14-2011, 09:18 PM   #4
mdowney's Avatar
Do you know which cut off wheel? And how do you cut a straight line with a handheld Dremel?
Mike Downey
Old 08-14-2011, 09:19 PM   #5
JFuel11's Avatar
Trader Rating: 144 (100%+)
Default Dremel...
Get yourself a good set of dremel bits and cutoff wheels and go to town... I have cut out many parts and chassis out of graphite/carbon fiber over the years with this method. I some times will print out the shape on paper from a cad drawing and stick it to the plate so I have a template or draw it on paper first.
Make sure you wear a dust maks. I didn't years back and am sure it will kill me before it is all said and done... :-)
Good Luck...
Alan Bachman (AKA - Johnny Rocket Fuel)
Help your fellow racers go faster... You will have more competition!!!
Sponsors:
RC America - XRay - Hudy - Maclan Racing - Xpert Servos - Schelle Racing Innovations - AKA Racing Products - DE Racing - Sticky Kicks - Sanwa
JFuel11 is offline   Reply With Quote
Old 08-14-2011, 09:22 PM   #6
mdowney's Avatar
Great idea! I'm just worried that hand-holding a Dremel will give me sloppy results.
Mike Downey
Old 08-14-2011, 09:38 PM   #7
Ediaz's Avatar
interesting idea, I would say hand held tool will be hard to cut straight , tagging along to see other responses.
I if I do it I would find a cutter i had a guy cut a carbon chassis before , years ago,and made me some aluminum arms for 20 bucks.
Recently tried to do my own limo chassis and broke while running, found a guy who did it perfect for me, but I suck at things like that.
E
Ediaz is offline   Reply With Quote
Old 08-14-2011, 09:50 PM   #8
It cuts so easy that you can get it pretty close to straight and then just use a flat block with some 180 sandpaper to finish off a straight edge. If you sink the cutoff wheel all the way into the material up to the shaft, the wheel uses itself to track straight.
Jamie Ferrell
www.jamairpaint.com
Old 08-14-2011, 09:52 PM   #9
i think band saw would do the job with fine blade and if need to be prefect little bit of sad paper on nice block can make it
-vtec- is offline   Reply With Quote
Old 08-14-2011, 10:03 PM   #10
toyoter91's Avatar
Trader Rating: 46 (100%+)
Send a message via AIM to toyoter91
normally you can find local shops that do cnc / carbon work that will do small runs of different parts for decent prices if you want that super clean / professional look.
toyoter91 is offline   Reply With Quote
Old 08-14-2011, 10:12 PM   #11
After you are done cutting which ever way you decide to go (I have done the cut off wheel rout before with good results) you can seal the edge with some CA glue to help protect the edges and your fingers
igofastracing is offline   Reply With Quote
Old 08-14-2011, 10:16 PM   #12
carcrazy699's Avatar
Trader Rating: 48 (100%+)
so where would be a good place to get the carbon from? I would like to make some top plates out of CF for my buggy
carcrazy699 is offline   Reply With Quote
Old 08-14-2011, 10:18 PM   #13
mdwaeracer's Avatar
Trader Rating: 19 (100%+)
Scroll saw,band saw,jig saw,dremel,cast saw,
mdwaeracer is offline   Reply With Quote
Old 08-14-2011, 10:23 PM   #14
TJMac's Avatar
Default I'd have to 2nd what Toyoter91 said.....
I was looking for CF suppliers online and stumbled across a company called Dragon Plate. Not only do they sell CF products but offer a CNC service at supposedly reasonable prices (I have not used their CNC service yet).
I've cut CF before and it sucks. You don't want to breathe the dust and it's really messy.
Tom
TJMac is offline   Reply With Quote
Old 08-14-2011, 10:52 PM   #15
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
McMaster Carr has CF plate.
http://www.mcmaster.com/#carbon-fiber/=dmigvd
For contoured jobs I use Fiberglast 3k 2x2 twill weave.
Yeti AS3 is offline   Reply With Quote
Losi 8ight Carbon Fiber Chassis Matrix Concepts Nitro Off-Road 201 01-18-2012 08:01 PM
Custom Carbon Fiber Parts - Cutting Technique and Safety soulstice Electric Off-Road 10 04-23-2011 06:10 PM
Cutting carbon fiber... rpespo Chat Lounge 6 03-18-2009 11:27 PM
CARBON FIBER AND KEVLAR SHEETS TUBES 4 SALE MAKE YOUR OWN RC PARTS robbdny R/C Items: For Sale/Trade 159 01-19-2009 07:43 PM
