The Official Atomik / Venom V2MR RedEdition® 2WD Race Spec Buggy >
Like Tree2Likes
Old 03-27-2013, 05:13 AM
  #241
Originally Posted by MOmo
I can't remember if I tried the spur. i know the pads fit in the stock spur (though thicker) but i don't think I tried the spur. i can check and let you know in a day or so.
I want to try them with a Rear configuration. At some point (when I have MONEY!!!!) I want to get 2 VMR2 chassis, one in Rear and one in the Mid configuration with the same equipment and see how each does.
I need to finish assembly, the good news is no shortage of tires. I'll be able to use my previous B4.1 tires since my Current 4.2 has the hex.
MOmo
yes i agree i want a second because my local track we run rear but im going to a race that is astroturf so im running mid motor for that
Slash King is offline
Old 03-27-2013, 11:40 AM
  #242
MOmo's Avatar
Originally Posted by jk racing
Ordered my car Thursday night, arrived today, with a few spares in case the wall moves in front of me.
Looked over the kit, not sure if I will start tonight or not, tired after a long day at work.
Good to hear Joey,
Keep us updated. LMK what you find as you build it. I am curious if your car has the same troubles mine did.
MOmo
MOmo is offline
Old 03-27-2013, 06:14 PM
  #243
Any of u guys run b4 wheels on the rear if so is any mods needed
Old 03-27-2013, 08:15 PM
  #244
jk racing's Avatar
Trader Rating: 20 (100%+)
read over the RCSOUP write up about the car, he uses B4 standard rears with no issues.
http://www.rcsoup.com/2013/03/atomik...gy-build-up/9/
jk racing is offline
Old 03-27-2013, 08:16 PM
  #245
MOmo's Avatar
I don't hink any mods are needed. I think they slot in just fine. I know I tried the Atomik rims on the B4 and it went on w/o a hitch.
Talked to Joey about his build and he said the AE rims are much lighter than the AT rims, so if saving weight is important, it could be a viable option.
MOmo
MOmo is offline
Old 03-27-2013, 11:52 PM
  #246
jk racing's Avatar
the Avid triad will NOT fit/work on this car.
on my B4:
on my V2MR:
Old 03-27-2013, 11:59 PM
  #247
jk racing's Avatar
also a quick tip...if you own/owned/built an HPI Blitz ESE, use the turnbuckle tool to build the turnbuckles on this car, same size & life is very easy
Old 03-28-2013, 07:33 AM
  #248
Default Alternate Body
At the track last night, small turnout, but tried different bodies on V2MR and found that a Kyosho RB5 body is very close, with enough room to use velcro on tub sides for mounting for guys that are tired of losing body clips. Just an option since Atomik is rather slow on making replacements available. Russ
russmustar is offline
Old 03-28-2013, 04:16 PM
  #249
What gearing are you guys running for stock
Old 03-29-2013, 07:15 AM
  #250
jk racing's Avatar
Zero mods needed
Old 03-29-2013, 06:20 PM
  #251
Papa88's Avatar
I got to see one run last weekend and the buggy looks good and the kid that ran it did good for his first time in mod buggy..
Papa88 is offline
Old 03-30-2013, 10:56 PM
  #252
MOmo's Avatar
Zero mods needed
Looks Good Joey.
I think i might re-config mine for mid motor since I have the B4.2 for R motor. LMK ur oil choice and if you think other springs will work better.
MOmo
MOmo is offline
Old 03-31-2013, 09:10 AM
  #253
Hey everyone, I am a small Venom/Atomik dealer and ordered a V2MR when they became available. It sat on my shelf for a little while since I've been transitioning from on road back to dirt. Its been about 20 years since I raced dirt!
Anyway, I was very impressed with kit overall. I had to clean up the front arms slightly, and my shocks were 1 e-clip short, but I was able to find one. I raced the buggy on Friday in a 17.5 sportsman class that was mixed with 4wd buggies. It was my first time driving the car, and basically spent the whole time tuning everything. The car handled very well, the rear stayed planted and front end push wasn't as bad as I thought it would be.
I did a practice day with the car yesterday and finally got the gearing where I wanted. All was well until the a pin snapped in one of the cvd's. I'm thinking the notch weakens them excessively. What does everyone think about using a roll pin instead?
I can also confirm that DE racing B4 rear wheels fit perfectly. The fronts are a bit more dificult. With the Associated bearings I found that the axle is a tad short so you cannot tighten the screw all the way. So, they work, but you have to tighten until they bind and then back off and let the loctite set up.
ericschlaifer is offline
Old 03-31-2013, 09:25 AM
  #254
Holly W's Avatar
I'm glad that you like the car, it really does drive well. I will try to get an updated setup posted shortly. Yes, roll pins work fine in the CVD's. That's what I have in my car. I wish I had advice for your wheel situation but I'm running the Atomik wheels.
Holly W is offline
Old 03-31-2013, 09:59 AM
  #255
I look forward to seeing it! I'm running a tekin RS boosted with a Venom Red 17.5 and 24/77 gearing. I had some servo geometry issues with a Savox 1251 installed. It sat too far forward. I just swapped it for a 1233SG which is enormous but fast! I thinned out the servo mounts to 3 mil to scoot the servo back and cut out the chassis for the back of it...worked out perfect with the fullsize stick pack. I'm waiting for them to get stock on some shorties and saddle packs so I can try them out. Here's how it came out.
As far as the wheels, I'm running some of both rims in the front. I'm just keeping the axles attached to the wheels and swapping axles . Its an odd way of doing it but it is working out.
