Old 07-21-2013, 09:26 PM   #4666
AndrewTom's Avatar
definitely just some.
look on the TLR blogspot post, thats the perfect amount to use.
too much, and it will create friction, and typically where there is friction, there is heat, and where theres heat, theres power loss.
Andrew T. Larson
AndrewTom is offline   Reply With Quote
Old 07-22-2013, 07:02 AM   #4667
JourneyMan's Avatar
Trader Rating: 89 (100%+)
http://www.youtube.com/watch?v=EToj2yX76NU
Use about 4 small drops of white lithium grease around the diff gear.
Thanks to - Jconcepts | Team Trinity/Revtech | Kal-gard
JourneyMan is offline   Reply With Quote
Old 07-22-2013, 09:18 AM   #4668
Trader Rating: 19 (100%+)
Wow I think they should actually build a little MORE play into the diff and allow you to shim it out. Mine seems just a TINY bit too wide for the case (RTR gear diff) and this seems to be what's causing my binding...
norco kid is offline   Reply With Quote
Old 07-22-2013, 10:57 AM   #4669
Butch Mann's Avatar
Trader Rating: 25 (100%+)
Be careful not to over tighten the screws in the diff case, that will also cause the gears to drag, they just need to be snug. Use loctite on the screws that go into the motor plate.
Pit Stop Hobbies www.pitstophobbies.net
Bumps and Jumps RC www.bumpsandjumpsrc.com
Butch Mann is offline   Reply With Quote
Old 07-22-2013, 02:22 PM   #4670
Should I run a 6.5 on a large low traction high temperature track? Or would a 7.5 be better? Also what gearing should I start with ?
ezekielrb is offline   Reply With Quote
Old 07-22-2013, 03:29 PM   #4671
Casper's Avatar
Trader Rating: 33 (100%+)
7.5 should be plenty of power. I have gearing and ESC setup for teking motor and ESC on my web site.
www.casper-rc.com
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 07-22-2013, 06:06 PM   #4672
www.casper-rc.com
do you think a 6.5 is to much? i have the 8.5 in my 22 buggy and its perfect in the 22 buggy. but because of the added weight i feel like the 7.5 might not be enough.
Old 07-22-2013, 06:36 PM   #4673
Casper's Avatar
For a low traction track a 6.5 will be too much I think.
Old 07-23-2013, 06:20 AM   #4674
Hello everyone
Can anyone tell me what oil goes to the Losi 22 buggy Gear diff ?
And whats the difference between the numbers like oil 3000 or 5000 or 7000 and so on.
I know Ball diff is better but im amateur and i dont really need all the upgrades
Thank you
roman76 is offline   Reply With Quote
Old 07-23-2013, 06:26 AM   #4675
Hello,
Higher number = thicker oil
If you're running on loose stuff start at 1000W
kjrell is offline   Reply With Quote
Old 07-23-2013, 06:40 AM   #4676
Airflow's Avatar
Hi, which brushless setup would be best for my application which is bashing and racing?
10.5 non boosted or 13.5 boosted?
I'm looking for more run time and top speed.
Airflow is offline   Reply With Quote
Old 07-23-2013, 06:48 AM   #4677
Trader Rating: 15 (100%+)
Well, ok, it's like this - more run time, get a 13.5. More top speed, get the 10.5. If you're racing, check out what the fast guys use at your track - there may have a motor limit, like a 17.5 class, best to ask. If you simply want to do high speed runs up and down your street, get a 10.5 and a higher capacity battery, like 5500mah+ and have fun.
Daragh Slowey
22-4 2.0/R10/Orion6.5/S6040/Nosram shorty
B5M/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is online now   Reply With Quote
Old 07-23-2013, 04:20 PM   #4678
Airflow's Avatar
Thanks for the reply. I already have a 10.5 non boosted set up in my ultima scr and after a year, my idle gear broke. So with my incoming tlr22 I want something that's kinder on the drivetrain but still yield the same or more topspeed than what currently have. I thought a boosted 13.5 would smash a non boosted 10.5 but having doubts if it can unload that extra rpm on a short course truck.
Old 07-25-2013, 06:17 AM   #4679
Originally Posted by kjrell View Post
Hello,
What you mean running on loose stuff ?
What will change if i use 10000 instead of 1000 oil ?
I still dont get it what changes if you use thick oil or more runny oil ?
I am practicing on the pro tracks indoor and outside and i want to race one day with the others so i really want to know how all this things works
Thank you again
Old 07-25-2013, 06:42 AM   #4680
Carranza76's Avatar
Thank you again
Start reading:
http://www.petitrc.com/reglages/Basi...ing/index.html
http://www.competitionx.com/rc-racing/rc-tuning-guide/
http://users.telenet.be/elvo/1/1_content.html
Pegasus Raceway
IERC Raceway
TLR & Tekin are my main squeeze's!
Yokomo BD7
Carranza76 is offline   Reply With Quote
TLR 22 Racing Buggy Thread devnull Electric Off-Road 21236 02-26-2017 04:57 PM
TLR 22T ??? markt311 Electric Off-Road 44 08-02-2011 09:39 PM
TLR 22 Racing truck? thecman26 Electric Off-Road 39 06-04-2011 03:04 PM
