TLR 22T Thread
#4516
I've started to modify the TLR 22T setup sheet to work with dropdown menus to make things go a little quicker when adjusting a setup. It is intended to work on an ipad, but requires a pdf editing app to use. Here are a couple pics of what it currently looks like. Would anyone else use one like this?
#4517
YESS YESS YESS YESS!!! I WOULD LOVE TO USE THIS!!! THIS IS AMAZING!!! GREAT WORK!!!
#4520
Suspended
Here's a conversion some guy did on petitrc you might look into, that enables you to use 2mm or 4mm trailing spindles and solves all the problems you're having or will have. http://www.petitrc.com/setup/losi/se...dModification/
#4521
#4522
Vertically shot vid (she forgot that she can rotate her phone cam and have the video be correct) of me driving my wife's Mid-Motor 22T today.
+ YouTube Video | |
#4524
What are peoples personal opinion of the 30/3 front end compared to the 25/5 on the 22T?
Cheese
Cheese
#4526
Suspended
22SCT to 22T front suspension conversion
I ran across this interesting conversion on petitrc.com in which someone has used the front suspension from the 22SCT for use on their 22T.
The biggest advantage of doing so is that it will allow you to use the 2mm and 4mm trailing steering spindles, to calm down the front end of the truck. The front end is narrower, but it appears he makes up for it by using wider offset T4 (hex) front rims.
It might be something some of you might be interested to look into.
#4527
http://www.team-durango.com/part-inf...artNo=TD330293
it may be just enough to get clearence of wheel.
#4528
I was thinking the same thing, will hit the track this weekend and give it a try.
Cheese
