my 2nd MMM esc burned
This is what i was running:
Hot Bodies D8T
gear 46/17
MMM/2200kv
1 2s + 1 3s = 5s Turnigy Lipo 5000mAh 40c
what could cause the esc flame and burn out in coupe minutes of run time? first is my 1 1/2 years old MMM esc, got burn and smoke, and then put a new esc in the next day, 5 minutes later is burned the same way again. Most likely is the Lipos right? or could be the motor? ( its pretty old too).
Hot Bodies D8T
gear 46/17
MMM/2200kv
Hot Bodies D8T
gear 46/17
MMM/2200kv
Hot Bodies D8T
gear 46/17
MMM/2200kv
sucks.. good luck maybe someone else has had these symptoms though and will speak up.
R/C Tech Elite Member
Hot Bodies D8T
gear 46/17
MMM/2200kv
Hot Bodies D8T
gear 46/17
MMM/2200kv
+1 Wow good catch, I didn't notice how over geared he was.. I'm surprised he has not had heat issue on the motor and w/ the lipo's as well. I've never run hb equipment so I didn't even think about the gearing... but yup big issues geared like that.
even on a 4s setup that is steep gearing.. but on 5s it's just way too much. As you increase voltage you need to decrease gearing if you are on the same motor. If you change motors to a better kv rating for 5s lipo it would help some but that gearing is just too high.
