is the an 8ight elec conversion thats known to be the best one?
Can't go wrong with RC Monster or Tekno.
Losi kit with the Elite RC motor mount is what I have in both buggy and truggy, rock solid. Just make sure you put foam on all sides of battery tray, otherwise it will break in half sooner or later from the battery strap tension.
Yes, I watched my Lipo eject off a 30 foot double....
I have a Losi 8T with a Tekno kit and will be waiting for the arrival of another 8T. Of course I'm converting that one and the best one looks like the Tekno V4.
It is a little more expensive ($34 more than the Losi kit) but its specifically designed for the conversion. Not just a battery tray and motor mount.
It has a complete chassis with driveshafts and the truggy kit even includes a rear chassis brace.
But its cheaper than the Losi kit and Elite motor mount that others have recommended anyways.
Its your nickel.
Its your nickel.
Just to update this thread so everyone else knows, if you are converting a Losi 8T 1.0, (which is what I'm doing) according to the Tekno instructions you also need to purchase a rear driveshaft, both 2.0 shock towers, body mounts and a 2.0 body.
Now the cost was almost $100 more than what the Losi kit was. For strictly racing, it might make sense but for me, it's mostly bashing.
See if you can guess which one I'm getting from Amain now?
I have run the Losi Conversion kit since it first came out with Zero problems.
You will be fine
You will be fine
i run the losi kit on mine and if you loctite all the plastic parts your good to go
