zippy flightmax 5000mah charging
hi everybody when im charging my zippy flightmax 5000mah battery with the imax b6-ac charger it is reading 8v a 1.0amp charging rate?
help
help
do i start charging a 5amps on balance mode chargeing mode or what?
it is only my first time chargeing and im chargeing on a imaz b6-ac
and how long will it tack it charge on 5amps?
its a 2 cell battery lipo so shouldnt the top voltage be 7.4 insted of 8.4?
hi,
as stated earlier, the amps will go down as you reach the full cap of the battery. After some charges though the battery will be able to take 5200mAh or maybe more.
In regards with your charger's amperage make sure it's power supply is able to give 1C (5A for your battery's case), otherwise the maximum will be your power supply output. the Output on the other hand if the previous is ok I believe you can regulate.
hope it sheads some light.
hi so now i charge on balance mode on 5amps and i plug in balanceing leads and the output thick leads
hi just another question how for apart can the voltages be of each cell because at the moment there 0.03 apart of each other
Discharged, that's fine, actually pretty good if discharge approaches 70-80%.
If they've been balance charged, no, they should be within .01 (10mv). Most balancer specs call for cell imbalance of less than 10mv. My better ones come off at the same voltage, the cheaper ones will show some diff and as they age, you will start seeing some imbalance.
You might want to look at your charger and see if its listed for your charger.
also im geting some coging when i take off
a but like ded-ded-ded-derrrr
but after i take off its fine
is my gearing to high or what can i program it to not do it like the launch boost thingy
