Old 10-07-2004, 07:49 PM   #1
Default B4 motor question
ok i have a p2k pro 27 turn in my B4. its pretty slow with that motor, probably less than 20mph. however when i put the same motor in my tc3 it flies! anyone know why this would be? also if i went to a 15 turn mod motor what kinda speed do you think i would get with the B4? thansk for your help!
Bonefish is offline   Reply With Quote
Old 10-07-2004, 08:04 PM   #2
Rysuleod's Avatar
The B4 has a gear box that is raising the gear ratio. I think it's around 2.6:1 for the gearbox alone not including the spur and pinion. Thats 2.6 turns of the motor while the gears and outdrive make one revolution.
Also the offroad car is no doubt heavier than the on road car.
I haven't seen a tc3 but I am guessing it's a straight pinion to spur gear on a live axle. Your gear ratio is probably lower in this case.
Rysuleod is offline   Reply With Quote
Old 10-07-2004, 08:37 PM   #3
ok, that makes sense. i was thinking of the spur and pinion, but not of the internal ratios from the diffs and transmision. still wondering what kinda speed i will get from a 15 turn motor in a B4. thansk for your help!!!!!!!!!!!
Old 10-07-2004, 09:05 PM   #4
WheelNut's Avatar
Send a message via MSN to WheelNut
Check your gearing chart in your manual. Your B4 should be only minutely slower than your TC3, the drivetrain in the B4 is very effiecient, as is the TC3's. If you've lost your manual associated website has gearing charts and complete manuals avliable for free download. www.rc10.com
WheelNut is offline   Reply With Quote
Motor Question RoseTuned Electric On-Road 5 09-27-2007 11:50 AM
XXX-NT motor question Rookie01 Nitro Off-Road 12 06-26-2007 02:01 AM
Motor+ESC question SPO Electric On-Road 2 08-29-2006 05:29 PM
Motor fan question ChadCapece Electric On-Road 7 04-07-2005 10:09 AM
question about motor for ipc esc mf2rcr Electric Off-Road 2 08-11-2004 03:22 AM
SEO by vBSEO 3.5.0
