Old 06-09-2011, 03:04 PM   #1
Default Lipo wont charge
I have a Turnigy 35-45c discharge 5000mah lipo that says the balancer doesn't connect when I connect it to the battery charger and then it doesn't charge at all.
Im thinking its an issue with maybe the wiring connections got loose to the balancer.
Anyways can this be repaired or does it have to be thrown out?
JimmyS1985 is offline   Reply With Quote
Old 06-09-2011, 03:06 PM   #2
Trader Rating: 20 (100%+)
try charging it in nimah mode for a few min then put it back into lipo mode.if that doesnt work then you have a bad cell/cells
toyota 2jz is offline   Reply With Quote
Old 06-09-2011, 03:07 PM   #3
TailsNeon556's Avatar
did you try charging it without the balancer? could be an open in the balancing connector / wiring / port.. it isnt needed all the time.. i almost never balance my packs and haven't had any issues.. when i do throw it on .. they are very close
Derek Lombardi
Kyosho RB6 - Kyosho RB5 SP2 WC +15 - Kyosho Lazer ZX-5 FS2 - Kyosho MP9 TKI2
Island Raceway & Hobby - PCR bodies
TailsNeon556 is offline   Reply With Quote
Old 06-09-2011, 04:39 PM   #4
just return it and see if they take it back.
rsmugs is offline   Reply With Quote
Old 06-09-2011, 04:48 PM   #5
Matt Howard's Avatar
return it back to Hobbyking? yeah, good luck with that
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 06-09-2011, 04:53 PM   #6
I tried hooking it up without the balancer but it did not work.
Old 06-09-2011, 05:08 PM   #7
Then it sounds like you have an open in the pack somewhere.. if you hook up a voltmeter do you get a reading?
Derek Lombardi
Old 06-09-2011, 06:18 PM   #8
Try charging it at .0x (x being the 5 in 5000mah)
so if its 5000 MAH, charge at .05 mah
amagad is offline   Reply With Quote
Old 06-09-2011, 07:08 PM   #9
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Check the lipo with a meter to see if it reads both cells .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
lipo wont charge microbomb Electric Off-Road 6 06-10-2010 03:12 PM
New Turnigy Lipo wont charge fievel Electric Off-Road 9 05-08-2010 01:32 PM
My Lipo wont balance. Is it the charger or the lipo RaV3N Electric Off-Road 40 12-25-2009 01:49 PM
Lipo-no power-wont charge mach1rustler Radio and Electronics 10 08-20-2009 04:57 AM
