MAMBA MAX PRO COGGING "E_REVO"
Hi i have e-revo with a Brand new mamba max pro esc , new Tacon brushless motor 2000 KV on 6s lipos. it started cogging/glitching when i apply the throttle. It wont go forward until i give it a little tap and the motors turns over and works. But when i stop i have to give it another tap to go. Also if i pick up the car off the ground and give it throttle then the wheels when spin slowly until i let go. I dont know why it is doing this everything is brand new. Let me know if you have any questions or suggestions to try and fix this.
- Make sure your end points (or travel for Spektrum) on the radio are set the the max
- Re-bind the reciever
- re-calibrate the ESC
Sounds like the MMP is running in sensored mode or one of the motor wires are loose .
As was said before IF you are running a Mamba Max Pro its not gonna last very long on 6s in a heavy truck like the E REVO . Sell it and get a Mamba Monster ESC , it can handle more power and is made for heavy trucks like the E REVO . The Mamba Max Pro is meant for smaller/lighter trucks .
