Ok to run only 40% EPA on throttle? (brushless)
#16
I took that from a post by Joe Ford of Castle Creations, speaking of the original Mamba Max on another forum. I am far from an expert or an EE, so my understanding is very incomplete.
I did not think the MOSFETs switched between the phases of the brushless motor, but only controlled the PWM to each phase. I could be way off, so if you know better please inform me.
#17
I don't personally use EPA to soften up a setup, but I know many people who do and it seems to work ok.
#18
If reducing the EPA hurts an ESC then why do we have throttle at all? That would mean every time you didn't use full throttle, you are hurting your equipment. So those of us on smaller tracks are damaging our equipment? That's BOGUS, a MYTH and anyone with half a brain knows it.
#19
The FETs are divided up into groups of 6 to form a 3 phase bridge. They do PWM and switch between the phases in some sense. Even when you are at full throttle, they are still switching. They never go to 100% on like the old brushed controllers did. At the very least, they still have to turn on and off a few times per rotation. This switching would be slower than the PWM frequency, but still represents switching.
So what is the PWM frequency?
#20
#21
I dont think anyone has said it is hurting your equipment, except maybe a few manufacturers who wanted you to buy another motor after blowing your first paycheck on a 9000kv for your Slash. (not you in particular) The idea is that everything is at it's most efficient when at full throttle and it can, in some cases, cause more heat.
#23
My finger seems to be either in full throttle or at neutral...LOL rarely ever on the brakes...
Thats why i limit performance with throttle %age. having that full throttle there when i need it is beyond my trigger fingers ability and just gets me in trouble.
this is only necessary, of course ,when you have something that is grossly overpowered or the track conditions are especially slippery
