Titanium Parts?
#16
I have never experienced any Titanium that was brittle. Now, it can become brittle when heated, as it reacts with oxygen above 800 degrees or so, which is why Ti exhuast headers often crack, and why there is sometimes issues when using it for valves, and why it's best to weld titanium in a box. However, Titanium is not brittle. It's QUITE flexable and resilient. Shear strength is marginal, but that doesn't constitute being brittle.
I also have never had any issues with the Ti springs you mentioned. I only rode with one Ti spring on the rear shock for motocross, so my sample range is not large, but the spring ordered to my specs worked just as a steel spring, but lighter and stayed consistent for the time I had the bike. I did not have to adjust the compression to rebound any differently than a steel spring.
I too have never seen brittle Ti ?
#17
Titanium can be alloyed to be very useful in spring applications. However, when we tested with them in 1:1 trucks our rebound values were 20-30% less than with conventional spring steels from Eibach or Hypercoils. The loss in unsprung weight is significant, and provided you have the budget (very expensive to have custom length titanium coils made) and again the means to independly adjust your rebound settings from your compression settings, I.e. customizable valving stacks, it can be advantageous. The example you gave of the dirtbike using a titanium rear spring has separate adjustment as is needed, though the factory did the R&D for you already so its pretty much set and only requires some fine tuning for the majority of riders. Rc cars, as you know, have pistons and various oil weights to accomplish dampening, but as of yet there is no method developed to adjust the compression and rebound strokes separate from one another.
EDIT: Bad memory here- the titanium springs actually rebound faster than conventional springs, making for 20-30% higher rebound values.
Its mentioned in the post below this one, but has anyone experimented with the tapered piston holes? May have to come up with a shock dyno for some quanitfiable results. While the 1:1 shocks seem more complex, I actually found them much easier to tune. We had charts and data that we could easily make 5 or 10% adjustments in the valving. Just not the same with the Rc shocks..
#18
it is extremely easy to have differant compression and rebound, thats what tapered pistons do, the bottom tapers up to have more rebound for rougher tracks, so I'm sure the same priciple could be applied to tune it to the desired effect. HPI also already makes titanium springs for drifting.
