traxxas slash problem HELP!!!!!
i have a slash 2wd with the novak 4400 and hv maxx esc running 2 6 cell 5000mah and the motor jumps when i go to take off. it is like it does not have enough power to turn the wheels what can i do to fix this problem i have tried 2 7 cells and it helped some. would a lipo help more?
Suspended
What do you mean motor jumps?
is pinion all the way on spur?
yes its up against it. it acts like the spur will turn about half a revolution then kick back a quarter revolution but it will get the truck goin and does stop when it goes it only does it maybe 5 or 6 time and stops as long as i am goin it dont do it just from a dead stop it might be gettin to much traction and the motor or battery dont got enough to turn the tires any ideas will help
Suspended
Maybe the transmission,
ask a guy at your lhs
Super Moderator
Trader Rating: 31 (100%+)
sonsor cable problem is my guess.
why are you running 2 packs anyway?
the novak hv maxx has to have two packs to even turn it on i dont understand it much myself. from my understanding of this motor it has to have 14.4 volts to operate properly
Super Moderator
ok..looked up your system.
Does it do it just when you punch the throttle from a dead stop or does it happen if you gently easy into the throttle from a dead stop?
no i can ease into it then go once it is rolling it is only when i punch it
Super Moderator
if your packs are at the end of their usable life that might be your issue. Got a buddy you could borrow a couple packs from and test it?
well tommorrow im goin to go buy two 3s lipo 6400 and chargers and i will see how that goes from wat i have been reading on here that is most likely my prob i hope but wat do you think?
Super Moderator
Is that system rated for 2 3s lipo packs? That's 22.2 volts
I believe your system is only rated to 2-2s packs
i do not know but i did just find out that i can run it with one 11.1 6400 lipo i just got to take one set of the battery wires i wont be usein and create a curcit but i would like to run two at the beach drags if it can hold it what do think would happen if i ran two??
Super Moderator
If it's only rated for a pair of 2s packs running 2 3s packs will kill it for sure.
IMO a pair of good 2s packs would give you more power than you've ever had with NIMH.
