Kinetic showing locked rotor and cogging
I have a two week old Kinetic running a 17.5 Ballistic in a Blitz. All was fine until......I was testing some new stuff, and decided to slowly add timing in the esc. After careful testing and timing progression, I ened up trying full boost on the speed control. I set the blitz on the ground. It ran two feet then stopped completely.
The esc led's indicated a locked rotor condition. I quickly removed all timing and set the timing back to factory specs.
When I placed the truck on the ground it went another two feet and again showed locked rotor. I gave it a little push start, it went, but cogged badly. I need some ideas...
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
If you do all that and still have the same problem, call Novak's tech support.
Thanks for the reply. I forgot to mention I tried a couple sensor wires. My gut feeling is a killed the sensor board. Im going to tear own the motor today. My gut is telling me, its the sensor board. I have a spare to try. I wish I knew why going to max timing killed the sensor board.
I took an old Novak SS brushless speed control and hooked it up to the 17.5 Ballistic fron the Kinetic kit. I ran two packs thru the old SS esc and the new 17.5. At least I know its not the motor or sensor board or sensor wire in the motor. Called Novak. They are looking into it.
You know, I am guessing that you have the Nova Link software on a laptop or computer somewhere near you...are you running the latest firmware?
Im gonna call and order it right now,
