SC10 help needed
SC10 help needed
I need to find new shocks but i don't know what shocks are the best for SC10.
Also, i have the reedy brushless that comes stock with the sc10 brushless but it keeps overheating when i use it. Any suggestions?
Why do you want new shocks? I just rebuilt my v1's with the rebuild kit and they are working fine. You can upgrade to v2 shocks but I wonder if you will actually see any improved performance. It seems like all shocks leak and need periodic rebuilding. After rebuilding the first shock, the next 3 went much faster. Do not believe I am having overheating problems with my brushless. Will leave that subject to someone with more experience. Good luck.
The oil keeps leeking out of the shocks. I have refilled them 3 times. Is this a sign that they need to be rebuilt or replaced?
Yep, time to rebuild. Kit costs $4 for all 4 shocks. There is a larger black o ring that goes on the top cap. There are 2 smaller red o rings that go inside the shock body. There should be instructions included in rebuild kit. Let us know if you need any help.
If your rebuilding make sure to lube up the o-rings with some shock oil or the thick diff oil. When putting on the rod ends use tape around the pliers or grab them as far down as possible. Make sure not to scratch the shafts, that will cause the o-ring to leak. Also dont cross thread the caps. It happens. ive never had them leak, but not doing these steps is why they say they do. hope it helps.
The V2 shocks are great, the rebuild is simple and the design is such that it virtually eliminates the leaking problem. Dont taint the Associated product with other brand shocks. May not be much difference in performance from V2 to V1, but the reliability of the V2 is better. The V1 could break down inside during a race, which would be bad. The ESC heating issue is mostly likely gearing, depending on available funds I would go with the Version two lrp ESC and LRP motor. I run the LRP SXX comp and an 8.5 LRP with the sintered rotor. Hope it helps.
Looks like you got some pretty good answers...
From now on, please post questions like these in the chassis specific threads...
Here is the SC10 thread....
http://www.rctech.net/forum/electric...ld-thread.html
